[gdal-dev] Motion: remove and deprecate a few drivers
Joaquim Manuel Freire Luís jluis at ualg.pt
Wed Mar 3 11:02:01 PST 2021
Even,
May you reconsider the Golden Software drivers --- GS7BG, GSAG, GSBG --- ?
GMT can read/write GSBG, but specially GS7BG, besides Surfer, GDAL is the only one that I know that is able to read this format. Maybe not in this list but there are still many people who use Golden software grid formats.
Joaquim
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: Wednesday, March 3, 2021 6:49 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Motion: remove and deprecate a few drivers
Following the discussions of past weeks, I motion to:
- remove the vector drivers BNA, AeronavFAA, HTF, OpenAir, SEGUKOOA, SEGY, SUA, XPlane and raster drivers BPG, E00GRID, EPSILON, IGNFHeightASCIIGrid, NTv1. They have all been authored by myself and I'm not aware of them having been much used or being still in use.
Implemented in https://github.com/OSGeo/gdal/pull/3373. They (driver code, doc and tests) have been moved to the https://github.com/OSGeo/gdal-extra-drivers
- deprecate the raster drivers DODS, FIT, GS7BG, GSAG, GSBG, JDEM, JPEG2000, JPEGLS, MG4LIDAR, GMT, DOQ1, DOQ2, FUJIBAS, IDA, LAN, MFF, NDF, SDTS, SGI, XPM, ZMAP and vector driver ARCGEN, ArcObjects, CLOUDANT, COUCHDB, DB2, DODS, FME, GEOMEDIA, GTM, INGRES, MONGODB, REC, SDTDS, TIGER, WALK. They will now be disabled at runtime by default, unless the GDAL_ENABLE_DEPRECATED_DRIVER_{drivername}
configuration option is set to YES, and will be removed in GDAL 3.5.
Implemented in https://github.com/OSGeo/gdal/pull/3505
Starting with my +1
Even
http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
