[gdal-dev] Motion: remove and deprecate a few drivers
    Even Rouault
    even.rouault at spatialys.com
    Wed Mar  3 12:22:28 PST 2021
Le 03/03/2021 à 21:20, Ivan Lucena a écrit :
> Even,
> Is the INGR driver for Integraph raster install needed?
> It was developed when the format was already deprecated.
> It was supposed to read old files and there was some old hardware,
> scanner, spitting out in that file format.
I'll add it to the list of deprecated drivers then.
Even
> Regards,
> Ivan
> *From:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Even
> Rouault <even.rouault at spatialys.com>
> *Sent:* Wednesday, March 3, 2021 3:07 PM
> *To:* Joaquim Manuel Freire Luís <jluis at ualg.pt>;
> gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Subject:* Re: [gdal-dev] Motion: remove and deprecate a few drivers
> OK, I amend my motion to keep GS7BG as non-deprecated for now. Let's
> mark GSAG and GSBG as deprecated and see if that triggers reactions once
> this is in the wild.
> Le 03/03/2021 à 20:55, Joaquim Manuel Freire Luís a écrit :
> >> Is the GSAG format really used ?
> > What can I say. Because it's a simple format I used to have
> colleagues that used it for I/O of their codes and not rarely it ended
> up in my hands. But can't honestly say it's much used.
> >> Which one(s) are proposed by default as output of current Surfer
> versions ?
> > GS7BG. In fact GMT can read the simple variations (without
> breaklines) of this somewhat complicated format
> >> Can't Surfer export to other formats already handled by GDAL ?
> > Yes, some. Nc and ArcInfo ascii at least
> > Le 03/03/2021 à 20:02, Joaquim Manuel Freire Luís a écrit :
> >> Even,
> >> May you reconsider the Golden Software drivers --- GS7BG, GSAG,
> GSBG --- ?
> >> GMT can read/write GSBG, but specially GS7BG, besides Surfer, GDAL
> is the only one that I know that is able to read this format. Maybe
> not in this list but there are still many people who use Golden
> software grid formats.
> >> Joaquim
> >> -----Original Message-----
> >> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even
> Rouault
> >> Sent: Wednesday, March 3, 2021 6:49 PM
> >> To: gdal-dev at lists.osgeo.org
> >> Subject: [gdal-dev] Motion: remove and deprecate a few drivers
> >> Hi,
> >> Following the discussions of past weeks, I motion to:
> >> - remove the vector drivers BNA, AeronavFAA, HTF, OpenAir,
> SEGUKOOA, SEGY, SUA, XPlane and raster drivers BPG, E00GRID, EPSILON,
> IGNFHeightASCIIGrid, NTv1. They have all been authored by myself and
> I'm not aware of them having been much used or being still in use.
> >> Implemented in https://github.com/OSGeo/gdal/pull/3373
> <https://github.com/OSGeo/gdal/pull/3373>. They (driver code, doc and
> tests) have been moved to the
> https://github.com/OSGeo/gdal-extra-drivers
> <https://github.com/OSGeo/gdal-extra-drivers>
> >> - deprecate the raster drivers DODS, FIT, GS7BG, GSAG, GSBG, JDEM,
> JPEG2000, JPEGLS, MG4LIDAR, GMT, DOQ1, DOQ2, FUJIBAS, IDA, LAN, MFF,
> NDF, SDTS, SGI, XPM, ZMAP and vector driver ARCGEN, ArcObjects,
> CLOUDANT, COUCHDB, DB2, DODS, FME, GEOMEDIA, GTM, INGRES, MONGODB,
> REC, SDTDS, TIGER, WALK. They will now be disabled at runtime by
> default, unless the GDAL_ENABLE_DEPRECATED_DRIVER_{drivername}
> >> configuration option is set to YES, and will be removed in GDAL 3.5.
> >> Implemented in https://github.com/OSGeo/gdal/pull/3505
> <https://github.com/OSGeo/gdal/pull/3505>
> >> Starting with my +1
> >> Even
> >> http://www.spatialys.com <http://www.spatialys.com>
> >> _______________________________________________
> >> gdal-dev mailing list
> >> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210303/9046fbb5/attachment.html>
