[gdal-dev] New JPEG 2000 Driver
Wed Mar 3 13:10:05 PST 2021
Folks,
When Andrew first mentioned RFC 34 I skimmed it and was a bit surprised it
existed though perhaps it seemed a wee bit familiar.  Now that Even
mentions it was not ever implemented I see that *I* proposed it and
presumably did not actually follow up on implementing it or getting it
adopted.   It still seems like a vaguely good idea, but also apparently one
without a compelling need since it has not been followed up on.
However, it does not solve the build-time problem posed by Greg.  I think
the approach that inclusion of reciprocally licensed or proprietary drivers
requiring explicit inclusion at configure time is a reasonable approach to
avoid accidental license violations by packagers.
Best regards,
Frank
On Wed, Mar 3, 2021 at 3:31 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> > https://gdal.org/development/rfc/rfc34_license_policy.html
> As indicated in the top of the RFC, its status is "development" (draft),
> which here means stalled/non-adopted given that it was proposed long
> time ago. So there's no runtime mechanism to control license compatibility.
> > But, I'm worried about something different.  As a packager, I'd like to
> > know that unless I take the affirmative step of passing --enable-foo,
> > for any GPLish or proprietary foo, I won't end up with a gdal build
> > linked with foo just because it happened to be present in my build
> > environment.
> This should normally be the case. One of the few GPL dependencies is
> Poppler and must be explicitly enabled with --with-poppler . Similarly
> with MySQL. All proprietary dependencies need also to be explicitly
> enabled AFAIK (you actually need to point to their SDK).
> GEOS (LGPL) is enabled by default is found.
> Even
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up   | Frank Warmerdam,
light and sound - activate the windows | +1 650-701-7823
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210303/3f611b25/attachment.html>
