[gdal-dev] New JPEG 2000 Driver
Greg Troxel
gdt at lexort.com
Wed Mar 3 14:55:47 PST 2021
Even Rouault <even.rouault at spatialys.com> writes:
>> But, I'm worried about something different. As a packager, I'd like to
>> know that unless I take the affirmative step of passing --enable-foo,
>> for any GPLish or proprietary foo, I won't end up with a gdal build
>> linked with foo just because it happened to be present in my build
>> environment.
> This should normally be the case. One of the few GPL dependencies is
> Poppler and must be explicitly enabled with --with-poppler . Similarly
> with MySQL. All proprietary dependencies need also to be explicitly
> enabled AFAIK (you actually need to point to their SDK).
Thanks. I'll report if I find any otherwise.
> GEOS (LGPL) is enabled by default is found.
That seems entirely reasonable to me.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210303/05773b0d/attachment.sig>
