[gdal-dev] Python Wheels for gdal
Idan Miara idan at miara.com
Fri Mar 26 12:56:17 PDT 2021
Hi all,
I'm wondering how difficult it would be to build the windows wheels with
the windows builder on the github CI
<https://github.com/OSGeo/gdal/blob/master/.github/workflows/windows_build.yml>,
I imagine we would need to install all the supported python versions to
build all the pyd files.
We might want to build a win32 version if anyone still cares about those.
Does someone have a different idea ? maybe a standalone builder script? but
then someone would need to run it manually I guess.
Idan
On Tue, 23 Feb 2021 at 16:13, Idan Miara <idan at miara.com> wrote:
> Hi Rob,
> Good point.
> I don't know - I've added Christoph to this thread.
> Christoph - can you share with us any build scripts or source file changes
> you make in order to build these wheels?
> I was able to combine the cp37+cp38+cp39 from Christoph's wheels for each
> platform by extracting the wheel files and repacking them in a single wheel
> per platform using a custom setup.py+setup.cfg
> The pyd files are very small so the overhead in wheel size is negligible.
> https://github.com/talos-gis/gdal-win
> Running build_all.bat creates:
> gdal-3.2.1-py37.py38.py39-none-win_amd64.whl
> gdal-3.2.1-py37.py38.py39-none-win32.whl
> (Note that this batch does not build the sources, just repacks the wheels)
> Idan.
> On Tue, 23 Feb 2021 at 16:02, Robert Coup <robert.coup at koordinates.com>
> wrote:
>> Hi Idan,
>> On Wed, 17 Feb 2021 at 12:24, Idan Miara <idan at miara.com> wrote:
>>> From what I can see, the gdal302.dll inside
>>> https://www.lfd.uci.edu/~gohlke/pythonlibs/#gdal doesn't depend on any
>>> non-windows DLL. All its dependencies are statically linked.
>>> Maybe until a better solution is found, and to remedy all the windows
>>> users who just want to `pip install gdal`,
>>> We could push Christoph Gohlke's wheels to pypi ?
>> Do you know if the build scripts for Christoph Gohlke's GDAL/related
>> builds are available? I don't think we could push any binaries on behalf of
>> GDAL unless people can reproduce or adapt them.
>> Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210326/13dd27c5/attachment.html>
