[gdal-dev] Can't access to points in a buffer returned geometry with OGR_G_GetX
Even Rouault
even.rouault at spatialys.com
Mon Mar 29 08:50:39 PDT 2021
Le 29/03/2021 à 17:46, Joaquim Manuel Freire Luís a écrit :
> Thanks,
> Maybe add that info to the docs? By now it only says
We would definitely appreciate your contribution !
> “OGR_G_GetX() Fetch the x coordinate of a point from a geometry.”
> *From:*Even Rouault <even.rouault at spatialys.com>
> *Sent:* Monday, March 29, 2021 4:43 PM
> *To:* Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Can't access to points in a buffer returned
> OGR_G_GetX() can only work on a Point or a LineString/LinearRing
> for a polygon, you need to extract the ring first with
> OGR_G_GetGeometryRef() / OGR_G_GetGeometryCount()
> Even
> Le 29/03/2021 à 17:26, Joaquim Manuel Freire Luís a écrit :
> OK, one more from the Julia wrappers. Playing with buffers now,
> and it works but I want to get the points and that fails
> julia> wkt = "POINT (1198054.34 648493.09)";
> julia> dbf = Gdal.buffer(Gdal.fromWKT(wkt), 500)
> Geometry: POLYGON ((1198554.34 648493.09,1198553.65476738 64 ... .09))
> julia> toWKT(dbf)[1:90]
> "POLYGON ((1198554.34 648493.09,1198553.65476738
> 648466.922021879,1198551.60094768 648440.8"
> The ‘toWKT()’ function calls OGR_G_ExportToWkt()
> But now if I try to extract the points with OGR_G_GetX() it errors
> julia> Gdal.OGR_G_GetX(dbf.ptr, 0)
> ERROR 6: Incompatible geometry for operation #
> ç============= ????
> 0.0
> julia> Gdal.OGR_G_GetPointCount(dbf.ptr) # ç=============
> Why so?
> 0
> Although the toWKT() works, tat’s an ascii representation but I
> want I want to access them in binary (not in WKB) to send to GMT.
> Joaquim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> http://www.spatialys.com <http://www.spatialys.com>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210329/15ca52d9/attachment-0001.html>
