[gdal-dev] Can't access to points in a buffer returned geometry with OGR_G_GetX
Joaquim Manuel Freire Luís
jluis at ualg.pt
Mon Mar 29 08:56:33 PDT 2021
Le 29/03/2021 à 17:46, Joaquim Manuel Freire Luís a écrit :
Thanks,
Maybe add that info to the docs? By now it only says
We would definitely appreciate your contribution !
OK, I owe you at least that. It's just a heavy first step (fork+PR) for this small thing but I'll do it.
"OGR_G_GetX() Fetch the x coordinate of a point from a geometry."
From: Even Rouault <even.rouault at spatialys.com><mailto:even.rouault at spatialys.com>
Sent: Monday, March 29, 2021 4:43 PM
To: Joaquim Manuel Freire Luís <jluis at ualg.pt><mailto:jluis at ualg.pt>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Can't access to points in a buffer returned geometry with OGR_G_GetX
OGR_G_GetX() can only work on a Point or a LineString/LinearRing
for a polygon, you need to extract the ring first with OGR_G_GetGeometryRef() / OGR_G_GetGeometryCount()
Even
Le 29/03/2021 à 17:26, Joaquim Manuel Freire Luís a écrit :
OK, one more from the Julia wrappers. Playing with buffers now, and it works but I want to get the points and that fails
julia> wkt = "POINT (1198054.34 648493.09)";
julia> dbf = Gdal.buffer(Gdal.fromWKT(wkt), 500)
Geometry: POLYGON ((1198554.34 648493.09,1198553.65476738 64 ... .09))
julia> toWKT(dbf)[1:90]
"POLYGON ((1198554.34 648493.09,1198553.65476738 648466.922021879,1198551.60094768 648440.8"
The 'toWKT()' function calls OGR_G_ExportToWkt()
But now if I try to extract the points with OGR_G_GetX() it errors
julia> Gdal.OGR_G_GetX(dbf.ptr, 0)
ERROR 6: Incompatible geometry for operation # ç============= ????
0.0
julia> Gdal.OGR_G_GetPointCount(dbf.ptr) # ç============= Why so?
0
Although the toWKT() works, tat's an ascii representation but I want I want to access them in binary (not in WKB) to send to GMT.
Joaquim
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210329/cc421137/attachment.html>
