[gdal-dev] Long Term Prognosis for JPEG 2000
Kurt Schwehr schwehr at gmail.com
Tue Mar 30 09:11:30 PDT 2021
Jp2k is likely to continue with heavy use for a long time to come.  There
are lots of hardware encoders in our solar system and the existing base of
data in that format is massive.  And with the improvements in Openjpeg,
it's support seems viable.  It's not the first choice for most, but that's
okay.
On Mon, Mar 29, 2021, 7:22 AM Aaron Boxer <boxerab at gmail.com> wrote:
> Hello There,
> I'm curious what folks here think about the future of JPEG 2000 in
> geospatial?
> I was having a little discussion about this over here:
> https://github.com/USGS-Astrogeology/ISIS3/issues/4237
> To me, the features that made JP2 unique amongst the many codecs were:
> 0. royalty free
> 1. support for lossy and lossless compression in a single framework
> 2. support for TB images
> 3. fast on-the-fly random access into large images
> 4. decoder can determine what sort of progression it uses at decode time:
> resolution,
> quality, component or spatial.
> 5. precise rate control
> 6. error and re-compression resilience
> 7. JPIP protocol for progressive transmission over low-bandwidth networks
> The cons to JP2 were:
> 0. computational complexity i.e. dog slow
> 1. (until recently) buggy and slow OSS implementations
> 2. patent questions (largely resolved)
> 3. poor support from HW and browsers
> Do you think there is currently a viable alternative which covers enough
> of the advantages while lacking enough of the negatives that plague JP2 ?
> I'm curious because I have been devoting quite a bit of time to addressing
> some of those negatives, as discussed at length previously,
> The standard remains essential in digital cinema, medical imaging and in
> the archive community. But, those last two fields may also be ripe for
> change.
> In digital cinema, precise rate control is a must, so I think it is here
> to stay in the area.
> Thanks,
> Aaron
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210330/4ce36103/attachment.html>
