[gdal-dev] Long Term Prognosis for JPEG 2000
Kurt Schwehr
schwehr at gmail.com
Tue Mar 30 09:16:34 PDT 2021
One downside in the jpeg2000 ecosystem that I have to call out:
Kakadu doesn't come with any tests unit tests. I tried to donate some
simple starter tests, but no luck getting traction. :(
On Tue, Mar 30, 2021, 9:11 AM Kurt Schwehr <schwehr at gmail.com> wrote:
> Jp2k is likely to continue with heavy use for a long time to come. There
> are lots of hardware encoders in our solar system and the existing base of
> data in that format is massive. And with the improvements in Openjpeg,
> it's support seems viable. It's not the first choice for most, but that's
> okay.
> On Mon, Mar 29, 2021, 7:22 AM Aaron Boxer <boxerab at gmail.com> wrote:
>> Hello There,
>> I'm curious what folks here think about the future of JPEG 2000 in
>> geospatial?
>> I was having a little discussion about this over here:
>> https://github.com/USGS-Astrogeology/ISIS3/issues/4237
>> To me, the features that made JP2 unique amongst the many codecs were:
>> 0. royalty free
>> 1. support for lossy and lossless compression in a single framework
>> 2. support for TB images
>> 3. fast on-the-fly random access into large images
>> 4. decoder can determine what sort of progression it uses at decode time:
>> resolution,
>> quality, component or spatial.
>> 5. precise rate control
>> 6. error and re-compression resilience
>> 7. JPIP protocol for progressive transmission over low-bandwidth networks
>> The cons to JP2 were:
>> 0. computational complexity i.e. dog slow
>> 1. (until recently) buggy and slow OSS implementations
>> 2. patent questions (largely resolved)
>> 3. poor support from HW and browsers
>> Do you think there is currently a viable alternative which covers enough
>> of the advantages while lacking enough of the negatives that plague JP2 ?
>> I'm curious because I have been devoting quite a bit of time to addressing
>> some of those negatives, as discussed at length previously,
>> The standard remains essential in digital cinema, medical imaging and in
>> the archive community. But, those last two fields may also be ripe for
>> change.
>> In digital cinema, precise rate control is a must, so I think it is here
>> to stay in the area.
>> Thanks,
>> Aaron
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210330/ae8c227b/attachment.html>
