[gdal-dev] using an in-memory file as -cutline argument in gdalwarp
Joaquim Manuel Freire Luís jluis at ualg.pt
Wed Mar 31 11:03:13 PDT 2021
This one is resisting. I can't spot any difference from your python example but it still fails.
What you mean by "Make sure that the cutline dataset is properly closed".
If I call GDALClose on it, then it disappears.
(note, I also tried by creating a "/vsimem/cut.shp" Memory cutline but the result was the same)
GDALGetDescription(ds.ptr)
"/vsimem/##280"
GDALClose(ds.ptr)
Sent: Wednesday, March 31, 2021 2:43 PM
To: Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] using an in-memory file as -cutline argument in gdalwarp
Joaquim,
yes, you should be able to use a /vsimem/ file as a cutline dataset. Here's an example in Python with a shapefile in /vsimem/:
https://github.com/OSGeo/gdal/blob/fec15b146f8a750c23c5e765cac12ed5fc9c2b85/autotest/utilities/test_gdalwarp_lib.py#L1103
The cutlineDSName= is just python syntaxic sugar to format the arguments. There's no reason it shouldn't work in Julia too
Make sure that the cutline dataset is properly closed, before using it with gdalwarp
Even
Le 31/03/2021 à 15:34, Joaquim Manuel Freire Luís a écrit :
I have low hopes on this one but have to confirm.
I have this "ds" dataset with one polygon geometry, which is correctly saved on disk with
ogr2ogr(ds, save="lixo.gmt")
and later correctly "cutlines" with
gdalwarp("IMG_9106.jpg", ["-cutline", "lixo.gmt", "-to", "SRC_METHOD=NO_GEOTRANSFORM"]);
but I wanted to avoid the step of saving to disk and instead using the inMemory file. If I ask its name, I see
"/vsimem/##258"
But this fails
gdalwarp("IMG_9106.jpg", ["-cutline", GDALGetDescription(ds.ptr), "-to", "SRC_METHOD=NO_GEOTRANSFORM"])
NULL Dataset
Can this be made to work (would it work with the python bindings?) and I'm just doing it wrong or it just can't?
Thanks
Joaquim
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210331/9bf29ce3/attachment.html>
