[gdal-dev] using an in-memory file as -cutline argument in gdalwarp
Even Rouault even.rouault at spatialys.com
Wed Mar 31 12:28:12 PDT 2021
Ah, is it using the Memory driver ? As I saw a /vsimem/ filename and
mention of gmt, I assumed you create a GMT file in /vsimem/, for which
my example would have worked. But if you use the Memory driver, there's
no way you can't use it as a cutline, since a dataset of the Memory
driver can't be re-opened. You can just use the handle returned by the
create method.
Le 31/03/2021 à 20:03, Joaquim Manuel Freire Luís a écrit :
> This one is resisting. I can’t spot any difference from your python
> example but it still fails.
> What you mean by “Make sure that the cutline dataset is properly closed”.
> If I call GDALClose on it, then it disappears.
> (note, I also tried by creating a "/vsimem/cut.shp" Memory cutline but
> the result was the same)
> GDALGetDescription(ds.ptr)
> "/vsimem/##280"
> GDALClose(ds.ptr)
> *From:*Even Rouault <even.rouault at spatialys.com>
> *Sent:* Wednesday, March 31, 2021 2:43 PM
> *To:* Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] using an in-memory file as -cutline argument
> in gdalwarp
> Joaquim,
> yes, you should be able to use a /vsimem/ file as a cutline dataset.
> Here's an example in Python with a shapefile in /vsimem/:
> https://github.com/OSGeo/gdal/blob/fec15b146f8a750c23c5e765cac12ed5fc9c2b85/autotest/utilities/test_gdalwarp_lib.py#L1103
> <https://github.com/OSGeo/gdal/blob/fec15b146f8a750c23c5e765cac12ed5fc9c2b85/autotest/utilities/test_gdalwarp_lib.py#L1103>
> The cutlineDSName=is just python syntaxic sugar to format the
> arguments. There's no reason it shouldn't work in Julia too
> Make sure that the cutline dataset is properly closed, before using it
> with gdalwarp
> Even
> Le 31/03/2021 à 15:34, Joaquim Manuel Freire Luís a écrit :
>     I have low hopes on this one but have to confirm.
>     I have this “ds” dataset with one polygon geometry, which is
>     correctly saved on disk with
>     ogr2ogr(ds, save="lixo.gmt")
>     and later correctly “cutlines” with
>     gdalwarp("IMG_9106.jpg", ["-cutline", "lixo.gmt", "-to",
>     "SRC_METHOD=NO_GEOTRANSFORM"]);
>     but I wanted to avoid the step of saving to disk and instead using
>     the inMemory file. If I ask its name, I see
>     "/vsimem/##258"
>     But this fails
>     gdalwarp("IMG_9106.jpg", ["-cutline", GDALGetDescription(ds.ptr),
>     "-to", "SRC_METHOD=NO_GEOTRANSFORM"])
>     NULL Dataset
>     Can this be made to work (would it work with the python bindings?)
>     and I’m just doing it wrong or it just can’t?
>     Thanks
>     Joaquim
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org  <mailto:gdal-dev at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev  <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> http://www.spatialys.com  <http://www.spatialys.com>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210331/703dfa47/attachment.html>
