[gdal-dev] GDAL /vsistdin/ 1MB limit
Andrew C Aitchison
andrew at aitchison.me.uk
Wed May 5 00:32:26 PDT 2021
On Tue, 4 May 2021, Romeo Alvaraz wrote:
> Thanks Even for the response and clarifications on /vsistdin/. Our reasons
> for attempting to use /vsistdin/ is to avoid having to read a file from the
> local file system (which we would have to write to first by other means) on
> our remote server. We've been using this in conjunction with /vsistdout/.
> /vsicurl/ was another option we considered for the input but it's not ideal
> to our situation.
> I'm just wondering if there is another handler/method you could suggest
> that could feed the input directly to gdal_translate in order to bypass use
> of file system?
A python script could store the incoming data in /vsimem/ and call
gdal_translate internally
Andrew C. Aitchison Kendal, UK
