[gdal-dev] GDAL /vsistdin/ 1MB limit
Romeo Alvaraz
THESUSHIMAN12 at GMAIL.COM
Tue May 4 19:02:38 PDT 2021
Thanks Even for the response and clarifications on /vsistdin/. Our reasons
for attempting to use /vsistdin/ is to avoid having to read a file from the
local file system (which we would have to write to first by other means) on
our remote server. We've been using this in conjunction with /vsistdout/.
/vsicurl/ was another option we considered for the input but it's not ideal
to our situation.
I'm just wondering if there is another handler/method you could suggest
that could feed the input directly to gdal_translate in order to bypass use
of file system?
Thanks.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
