[gdal-dev] exif dump?
Andrew Bell
andrew.bell.ia at gmail.com
Fri May 7 08:40:56 PDT 2021
I'm looking at gdalexif.cpp. I found a block of code that is guarded by:
#ifdef DUMP_EXIF_ITEMS
https://github.com/OSGeo/gdal/blob/master/gdal/gcore/gdalexif.cpp#L1545
I can find no other instance of this macro in the codebase so I'm assuming
that it's never defined. Can this block of code go away?
Thanks,
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210507/c808633e/attachment.html>
