[gdal-dev] exif dump?
Even Rouault even.rouault at spatialys.com
Fri May 7 09:02:50 PDT 2021
Andrew,
as indicated in the commented lines just after the #ifdef, it had been
used to generate the HTML file of the JPEG doc (the tables at
https://gdal.org/drivers/raster/jpeg.html), before the .rst era. We can
probably remove that now
Even
Le 07/05/2021 à 17:40, Andrew Bell a écrit :
> Hi,
> I'm looking at gdalexif.cpp. I found a block of code that is guarded by:
> #ifdef DUMP_EXIF_ITEMS
> https://github.com/OSGeo/gdal/blob/master/gdal/gcore/gdalexif.cpp#L1545
> <https://github.com/OSGeo/gdal/blob/master/gdal/gcore/gdalexif.cpp#L1545>
> I can find no other instance of this macro in the codebase so I'm
> assuming that it's never defined. Can this block of code go away?
> Thanks,
> Andrew Bell
> andrew.bell.ia at gmail.com <mailto:andrew.bell.ia at gmail.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210507/4890cdaa/attachment.html>
