[gdal-dev] gdal_translate clip PostGIS raster
Andreas Oxenstierna
andreas.oxenstierna at t-kartor.com
Tue May 11 23:11:54 PDT 2021
Tested with:
1 … table=rastertable WHERE=rid>0" dest.tif
Returns:
WHERE=rid>0 has no raster bands
2 … table=rastertable WHERE=rid=1" dest.tif
Returns:
a valid but empty tif file
3 … table=<view based on the rastertable" dest.tif
Returns:
... has no raster bands
gdalwarp seems to treat PostGIS raster tables as one subdataset for each tile. Basically make them useless in my mind - or have I missed something essential/simple ?
Hälsningar
Andreas Oxenstierna
T-Kartor Geospatial AB
Olof Mohlins väg 12 Kristianstad
mobile: +46 733 206831
mailto: andreas.oxenstierna at t-kartor.com<mailto:andreas.oxenstierna at t-kartor.com>
www.t-kartor.com<http://www.t-kartor.com>
On 11 May 2021, 08:48 +0200, Andreas Oxenstierna <andreas.oxenstierna at t-kartor.com>, wrote:
Thanks
but still stumbling (using 2.3.2)
gdalwarp -cutline "PG:dbname=gisdb" -csql 'select * from polytest where id=1' -crop_to_cutline -of GTiff -srcnodata -9999 -dstnodata -9999 "PG:<connectinfo> schema=a table=rastertable" dest.tif
returns:
ERROR 1: Input file <rastertable> has no raster bands.
gdalinfo reports that the table is tiled in 360 pieces which potentially is the source for the issue:
Subdatasets:
SUBDATASET_1_NAME=PG:host=
SUBDATASET_360_DESC=PostGIS Raster at
Hälsningar
Andreas Oxenstierna
On 10 May 2021, 19:31 +0200, Even Rouault <even.rouault at spatialys.com>, wrote:
Try with gdalwarp and the -cutline family of arguments
Le 10/05/2021 à 19:23, Andreas Oxenstierna a écrit :
Hi list
Is it possible to clip a PostGIS raster with a PostGIS vector poly using gdal_translate?
I cannot find a working syntax to define the clipping table in the WHERE clause.
Eg. this returns "Error browsing database for PostGIS Raster properties : ERROR: syntax error at or near "FROM"
gdal_translate -of GTiff "PG:<connectinfo> schema=a table=rastertable WHERE='ST_Intersects(rast,c.geom) AND c.id<http://c.id> = 2 FROM a.vectortable c'" a.tif
Best regards
Andreas Oxenstierna
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210512/a7748f02/attachment.html>
