[gdal-dev] A Swift wrapper for GDAL
Gaige B. Paulsen
osgeo at gbp.gaige.net
Wed May 19 09:38:09 PDT 2021
I’ve been using GDAL on macOS for years (and iOS as well, both mostly
with Objective-C) using C bindings and some Objective-C helpers that
I’ve put together over time. The C bindings are suitable for use with
Objective-C and shouldn’t be difficult to use as a bridge to Swift.
Also, if necessary, wrapping a C++ library in Objective-C(++) is
relatively simple and I’ve found that effective where I needed to use
the more advanced features (as Even points out, this has been very
infrequent).
I’m not sure how much time I have to commit to assisting with the swift
wrapper, but I’m happy to act as a sounding board and help where I have
time.
-Gaige
On 2021-05-19 12:13, gdal-dev-owner at lists.osgeo.org wrote:
> Your message has been rejected, probably because you are not
> subscribed to the mailing list and the list's policy is to prohibit
> non-members from posting to it. If you think that your messages are
> being rejected in error, contact the mailing list owner at
> gdal-dev-owner at lists.osgeo.org.
