[gdal-dev] A Swift wrapper for GDAL
Roberto Arista arista.rob at gmail.com
Thu May 20 08:32:42 PDT 2021
@Evan
> the C API is what is commonly used to create bindings to other languages
Good to know, thanks!
@Gaige
> Also, if necessary, wrapping a C++ library in Objective-C(++) is relatively simple and I’ve found that effective where I needed to use the more advanced features (as Even points out, this has been very infrequent).
I have almost no experience in writing ObjC, the only experience I have is through the python PyObjC wrapper. I don’t really know if it makes sense for my project.
> I’m not sure how much time I have to commit to assisting with the swift wrapper, but I’m happy to act as a sounding board and help where I have time.
Thanks, I appreciate it
@John: thanks for sharing your experience!
> I agree with Gaige that wrapping C++ code in Objective-C++ is relatively simple. At least, it is simple in concept. It is quite tedious in practice. Each C++ class requires 3 files: a public header, a private header for C++, and an Objective-C++ implementation. This, along with any required Swift customizations in the bridging header, would give you the highest-quality interface. But it is a ton of tedious, albeit simple, work.
Considered my level of experience with this technological stack, tedious and simple could work. But I first need to understand if it is worth the effort.
> I have an abandoned side project that uses XQuery to parse the GDAL doxygen XML and emit stub Objective-C++ file triplets for all GDAL classes. They are actually a bit more than stubs, they can pass the parameters through in a method call. I haven’t touched it in a couple of years. It is certainly incomplete. And it's in XQuery, <evil laugh>. But I’ll be happy to send it to you if you want.
That would be great, so I could get a better sense of how this double wrapper should work.
Best
Roberto Arista
ಠ_ಠ
Mobile: +39 366 4537413
> On 20 May 2021, at 00:44, John Daniel <jdaniel at etresoft.com> wrote:
> Hello Robert,
> I’ve looked at this myself a few times. Here are some interesting points:
> GDAL already supports SWIG bindings. If you are really into Swift, then you could potentially add Swift to SWIG and get support that way.
> I would not recommend using the C interface. The C interface is already a wrapper around C++. The few times I’ve tried it, I found that some C++ inevitably leaked out. This isn’t a big problem with modern C compilers. But I think it could potentially cause a lot of problems for the Swift C importer. I really don’t think this would yield a high-quality Swift interface. Swift fans would probably not be happy with it. This might be the easiest path to try, however.
> I think a bigger problem here might be Swift itself. There is a strong social component to the language and its adoption. As a consequence, the language is in a constant state of flux. And this is one of the reasons why I think using the C interface would not be popular in the Swift community. GDAL itself is written in an ancient style of C++. It is radically different than a modern C++ project, such as Boost. If you are into OGR, I recommend taking a look at Boost Geometry to an example of what GDAL written in modern C++ could be like. But Swift isn’t like C++. You can’t use an ancient version of Swift. Modern Xcode will refuse to even look at it. The more you write in Swift, the more you expose yourself to breaking changes in the language itself.
> I’m not trying to dissuade you here. I’m just suggesting that you be aware of some of these issues.
> My recommendation would be a new, Objective-C++ bridge interface that provides a greatly simplified, high-level interface to any required GDAL functionality. This is the approach I am taking with some SwiftUI apps I have under development. But this really isn’t a collaborative approach. Each app would have its own, unique needs.
> John Daniel
> Etresoft, Inc.
>> On May 19, 2021, at 10:08 AM, Roberto Arista <arista.rob at gmail.com> wrote:
>> Dear gdal-dev list,
>> I would like to use the GDAL library for a macOS project using the Swift language. Wrapping a C++ library in Swift is not straightforward at all, and I could not find a satisfactory solution so far.
>> There are a few projects on GitHub:
>>> https://github.com/optionu/Humboldt
>>> https://github.com/ranveerm/SwiftGDALProject
>> but they are either incomplete or outdated
>> So, I'll probably have to write the wrapper myself. Before even planning the work, I have a few questions for the list. My focus will be on the OGR module of the library.
>> - From what I've read so far, wrapping a C library in Swift is way easier than working with C++. I've seen from the docs that GDAL has both C and C++ APIs. Besides the difference between the two languages, do the APIs offer different functionalities?
>> - Is anyone willing to join forces to work on a GDAL wrapper for Swift? Or, is any expert developer willing to help me writing the wrapper? Of course, I am going to release the code with an open-source license.
>> Best
>> Roberto Arista
>> ಠ_ಠ
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
