[gdal-dev] Raster Attribute Tables
Even Rouault
even.rouault at spatialys.com
Wed May 26 02:22:00 PDT 2021
Met,
This is definitely not a GDAL limitation, but might be a ArcMap one. The
.aux.xml file can support a RAT per band.
Even
Le 26/05/2021 à 01:22, Met Bas a écrit :
> Hello,
> I've heard conflicting information about this in general casually and rather
> than test and make assumptions on results, was hoping to get some informed
> answer.
> I've read that Raster Attribute Tables must be created on single band
> GeoTIFFs. Furthermore, ArcMap requires that to make Raster Attribute Tables,
> the GeoTIFF must be single band.
> Is this a limitation of ArcMap or a limitation of GeoTIFFs? Is there any
> reason why it may be a bad idea to generate a Raster Attribute Table for a
> multi-band GeoTIFF using GDAL?
> Thanks,
> Met Bas
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
