[gdal-dev] Has gdal_ls.py been replaced?
Even Rouault
even.rouault at spatialys.com
Wed May 26 02:23:09 PDT 2021
Matt,
The sample files have been moved. You can find it at
https://github.com/OSGeo/gdal/blob/master/gdal/swig/python/gdal-utils/osgeo_utils/samples/gdal_ls.py
Even
Le 26/05/2021 à 01:12, Matt.Wilkie at yukon.ca a écrit :
> Hi,
> I only see gdal_ls.py in historical versions:
> https://github.com/OSGeo/gdal/blob/e346a31f3119f3bb3f77dd7ddc8037b3049c2026/gdal/swig/python/samples/gdal_ls.py
> I’m picking up on a very old suggestion[0] to use it as part of a
> chain to help gdaltindex generate footprints for images inside .zip
> archives. Before I go too far down that road though I figured I should
> see if this old sample is gone because it’s been superseded or
> absorbed into something else.
> [0]:
> https://gdal-dev.osgeo.narkive.com/o01sCeuU/gdaltindex-with-wildcard-tif-in-a-vsizip-myzip-zip
> <https://gdal-dev.osgeo.narkive.com/o01sCeuU/gdaltindex-with-wildcard-tif-in-a-vsizip-myzip-zip>
> *Matt Wilkie*
> Geomatics Developer & Administrator
> Environment | Technology, Innovation and Mapping
> T 867-667-8133 | _Yukon.ca <http://yukon.ca/>_
> /Hours: 08:30-16:30, Tue-Wed: Office, Thu-Fri: Remote./
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210526/33592c2c/attachment.html>
