[gdal-dev] nodata value and alpha in Float32
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon May 31 10:14:11 PDT 2021
Thank Even.
I think I found the reason of the problem. It is reproduced with more
bands. I created a second band just swapping the values in the diagonal.
Then, adding the second band to the tmp.vrt (2 normal + 1 alpha), and
following your steps, it is noticeable in the second band of the output:
$ cat test2.asc
ncols 2
nrows 2
xllcorner 440720.000000000000
yllcorner 3750120.000000000000
cellsize 60.000000000000
NODATA_value -10000
-10000 1.0
2.5 0.5
$ cat tmp.vrt
<VRTDataset rasterXSize="2" rasterYSize="2">
<GeoTransform> 4.4072000000000000e+05, 6.0000000000000000e+01,
0.0000000000000000e+00, 3.7513200000000000e+06, 0.0000000000000000e+00,
-6.0000000000000000e+01</GeoTransform>
<VRTRasterBand dataType="Float32" band="1">
<NoDataValue>-10000</NoDataValue>
<ComplexSource>
<SourceFilename relativeToVRT="1">test.asc</SourceFilename>
<SourceBand>1</SourceBand>
<NODATA>-10000</NODATA>
</ComplexSource>
</VRTRasterBand>
<VRTRasterBand dataType="Float32" band="2">
<ComplexSource>
<SourceFilename relativeToVRT="1">test.2.asc</SourceFilename>
</ComplexSource>
</VRTRasterBand>
<VRTRasterBand dataType="Float32" band="3">
<ColorInterp>Alpha</ColorInterp>
<ComplexSource>
<SourceFilename relativeToVRT="1">test_alpha.asc</SourceFilename>
</ComplexSource>
</VRTRasterBand>
</VRTDataset>
$ gdal_translate test.tif /vsistdout/ -of aaigrid -b 2 -outsize 1 1
ncols 1
nrows 1
yllcorner 3751200.000000000000
cellsize 120.000000000000
NODATA_value -10000
-3332.166748046875
I have not looked at the code, but seems that the mask is requested only
for the first band. Then the pixels in the other bands that are nodata, but
are valid in the first band are computed as valid... using -10000 in this
case. Looks like requesting the mask per band would fix it, right?
If this is the case, the alpha band is not the problem (confirmed removing
it from the tmp.vrt file).
Cheers
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Mon, 31 May 2021 at 17:28, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> mixing Alpha and NoData is generally not a good idea. Behavior will be
> different according to which part of the code is triggered. As far as I can
> see, the warping code should be able to handle both, but overview building
> will use the return of GDALRasterBand::GetMaskBand(), and when you have
> both nodata and alpha, this should be from the nodata value.
> Confirmed by the following little experiment, so I'm not sure why you get
> what you get:
> $ cat test.asc
> ncols 2
> nrows 2
> NODATA_value -10000
> 0.5 1.0
> 2.5 -10000
> $ cat test_alpha.asc
> ncols 2
> nrows 2
> NODATA_value -10000
> 255 255
> 255 255
> $ cat tmp.vrt
> <ComplexSource>
> </ComplexSource>
> </VRTRasterBand>
> <ComplexSource>
> </ComplexSource>
> </VRTRasterBand>
> </VRTDataset>
> $ gdal_translate tmp.vrt test.tif
> $ gdaladdo -r average test.tif 2
> $ gdal_translate test.tif /vsistdout/ -of aaigrid -b 1 -outsize 1 1
> ncols 1
> nrows 1
> NODATA_value -10000
> 1.3333333730697631836
> Even
> Le 31/05/2021 à 16:55, Javier Jimenez Shaw a écrit :
> Hi
> I have a GeoTIFF with this characteristics:
> - 6 bands
> - last band is "Alpha" (with values 0 or 255, nothing else)
> - Float32
> - NoData value = -10000
> The 5 first bands may have "nodata" pixels, not necessarily on all bands
> simultaneously. (nodata pixels are usually broken or saturated pixels from
> the sensor, and each band comes from a different sensor). The valid pixels
> have values between 0 and 1
> When I try to generate embedded overviews (with average interpolation)
> with C++ or CreateCopy as COG (with default values), looks like it is using
> the -10000 values as valid values, and producing results in the overviews
> like -9990.6... that obviously are not anymore considered "nodata".
> The first noticeable effect opening the file in QGIS, is that the min and
> max value for each band are not anymore 0 and 1, but nonsense negative
> numbers.
> Can both Alpha and NoData live together properly?
> Thanks.
> PS I have the impression that with external ovr file it does not happen. I
> am testing more.
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210531/da90c2f7/attachment-0001.html>
