[gdal-dev] nodata value and alpha in Float32
Even Rouault
even.rouault at spatialys.com
Mon May 31 10:37:22 PDT 2021
Javier,
> I have not looked at the code, but seems that the mask is requested
> only for the first band.
You're right. GDALRegenerateOverviewsMultiBand() in
https://github.com/OSGeo/gdal/blob/master/gdal/gcore/overview.cpp#L5057
always takes the mask from the first band. Which is OK for an alpha band
or a per-dataset materialized mask, but not for nodata. Please file a
ticket about that.
Even
> Then the pixels in the other bands that are nodata, but are valid in
> the first band are computed as valid... using -10000 in this case.
> Looks like requesting the mask per band would fix it, right?
> If this is the case, the alpha band is not the problem (confirmed
> removing it from the tmp.vrt file).
> Cheers
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Mon, 31 May 2021 at 17:28, Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>> wrote:
> Javier,
> mixing Alpha and NoData is generally not a good idea. Behavior
> will be different according to which part of the code is
> triggered. As far as I can see, the warping code should be able to
> handle both, but overview building will use the return of
> GDALRasterBand::GetMaskBand(), and when you have both nodata and
> alpha, this should be from the nodata value.
> Confirmed by the following little experiment, so I'm not sure why
> you get what you get:
> $ cat test.asc
> ncols 2
> nrows 2
> xllcorner 440720.000000000000
> yllcorner 3750120.000000000000
> cellsize 60.000000000000
> NODATA_value -10000
> 0.5 1.0
> 2.5 -10000
> $ cat test_alpha.asc
> ncols 2
> nrows 2
> NODATA_value -10000
> 255 255
> 255 255
> $ cat tmp.vrt
> <VRTDataset rasterXSize="2" rasterYSize="2">
> <GeoTransform> 4.4072000000000000e+05, 6.0000000000000000e+01,
> 0.0000000000000000e+00, 3.7513200000000000e+06,
> 0.0000000000000000e+00, -6.0000000000000000e+01</GeoTransform>
> <VRTRasterBand dataType="Float32" band="1">
> <NoDataValue>-10000</NoDataValue>
> <ComplexSource>
> <SourceFilename relativeToVRT="1">test.asc</SourceFilename>
> <SourceBand>1</SourceBand>
> <NODATA>-10000</NODATA>
> </ComplexSource>
> </VRTRasterBand>
> <VRTRasterBand dataType="Float32" band="2">
> <ColorInterp>Alpha</ColorInterp>
> <ComplexSource>
> <SourceFilename
> relativeToVRT="1">test_alpha.asc</SourceFilename>
> </ComplexSource>
> </VRTRasterBand>
> </VRTDataset>
> $ gdal_translate tmp.vrt test.tif
> $ gdaladdo -r average test.tif 2
> $ gdal_translate test.tif /vsistdout/ -of aaigrid -b 1 -outsize 1 1
> ncols 1
> nrows 1
> yllcorner 3751200.000000000000
> cellsize 120.000000000000
> NODATA_value -10000
> 1.3333333730697631836
> Even
> Le 31/05/2021 à 16:55, Javier Jimenez Shaw a écrit :
>> Hi
>> I have a GeoTIFF with this characteristics:
>> - 6 bands
>> - last band is "Alpha" (with values 0 or 255, nothing else)
>> - Float32
>> - NoData value = -10000
>> The 5 first bands may have "nodata" pixels, not necessarily on
>> all bands simultaneously. (nodata pixels are usually broken or
>> saturated pixels from the sensor, and each band comes from a
>> different sensor). The valid pixels have values between 0 and 1
>> When I try to generate embedded overviews (with average
>> interpolation) with C++ or CreateCopy as COG (with default
>> values), looks like it is using the -10000 values as valid
>> values, and producing results in the overviews like -9990.6...
>> that obviously are not anymore considered "nodata".
>> The first noticeable effect opening the file in QGIS, is that the
>> min and max value for each band are not anymore 0 and 1, but
>> nonsense negative numbers.
>> Can both Alpha and NoData live together properly?
>> Thanks.
>> PS I have the impression that with external ovr file it does not
>> happen. I am testing more.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> http://www.spatialys.com <http://www.spatialys.com>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210531/967fb1b9/attachment.html>
