[gdal-dev] current geolocation array implementation status
    Frank Warmerdam
    warmerdam at pobox.com
    Wed Nov  3 06:14:10 PDT 2021
Frederico,
I've updated the ticket to reflect that I backed away from work on a new
implementation.  I would still like to see a reliable geolocation
transformer.
I am also still interested in the general topic of iterative approximate
inverses for transformers which are not inherently invertible.
Best regards,
Frank
On Tue, Nov 2, 2021 at 1:18 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Frederico,
> Le 01/11/2021 à 23:22, Frederico Liporace a écrit :
> > Hello,
> > I'm debugging an artifact that I encountered while using geolocation
> arrays:
> > https://github.com/OSGeo/gdal/issues/4707
> > While searching I found this ticket mentioning that the backward map
> > implementation is broken and a new implementation is being considered:
> > https://trac.osgeo.org/gdal/ticket/6959
> > I could help with this implementation. Is there more context available
> > on why it is being reconsidered? It seems to me that the general case
> > for the backward implementation is very hard - for instance, what kind
> > of discontinuities (gaps, overlaps) would be allowed in the
> > geolocation array? Would it be expected to be robust enough to correct
> > the Landsat 7 ETM+ SLC-off for instance? My guess is not.
> Yes the general case is likely hard and would probably require special
> techniques that could possibly be sensor specific. I guess the
> requirements for improvements on the existing code would be at least not
> degrade what works currently.
> An idea for a new implementation would be to use an iterative process
> using the backward map as an initial guess and then iterating with the
> bilinear interpolation of the forward path to refine the solution up to
> convergence to some threshold of error to decide (could be 15% of a
> pixel size like the default setting of the gdalwarp approximate
> transformer of coordinate transformations)
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up   | Frank Warmerdam,
light and sound - activate the windows | +1 650-701-7823
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211103/11adb8f5/attachment.html>
