[gdal-dev] GeoTIFF gdalwarp puzzle
Carl Godkin
cgodkin at gmail.com
Fri Nov 5 08:02:30 PDT 2021
Thanks for checking, Jukka.
I am using GDAL 3.3.3 and get a smaller range:
d:\gdal-3.3.3\bin64\gdalwarp.exe -t_srs epsg:4326 "Caribbean 2 VFR
Chart.tif" caribbean_4326.tif
Copying color table from Caribbean 2 VFR Chart.tif to new file.
Creating output file that is 18714P x 10830L.
Processing Caribbean 2 VFR Chart.tif [1/1] :
0...10...20...30...40...50...60...70...80...90...100 - done.
Is there a bug fix between 3.3.3 and 3.4.0 that could account for this?
Meanwhile, I'll try to get GDAL 3.4.0 going here. Thanks,
carl
On Fri, Nov 5, 2021 at 7:51 AM Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Works for me on Windows with GDAL 3.4.0dev and Oct 07 2021 version of the
> file.
> gdalwarp -t_srs epsg:4326 "Caribbean 2 VFR Chart.tif" caribbean_4326.tif
> Creating output file that is 18583P x 12118L.
> The map in caribbean_4326.tif is complete.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Carl
> Godkin
> *Lähetetty:* perjantai 5. marraskuuta 2021 16.25
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] GeoTIFF gdalwarp puzzle
> Hi,
> I'm working with some aviation charts and found one that behaves in a
> puzzling manner.
> This page
> https://www.faa.gov/air_traffic/flight_info/aeronav/digital_products/vfr/
> has two Caribbean VFR charts in GeoTIFF format.
> I have been trying to run gdalwarp on "Caribbean 2 VFR Chart.tif" but I
> only ever get a small area out of the map instead of the whole extent.
> Specifically this command gives me just a smaller area output GeoTIFF:
> gdalwarp -t_srs EPSG:4326 "Caribbean 2 VFR Chart.tif" out.tif --debug ON
> I don't see anything from the debug output that explains this.
> The other chart, "Caribbean 1 VFR Chart.tif," does not behave this way,
> though the debug output from the same gdalwarp operation is much longer.
> I can't see anything wrong.
> I dragged both files into ArcGIS desktop explorer and both are displayed
> in the proper location and in their entirety.
> (I actually have a more elaborate workflow that works fine with chart #1
> but this is the simplest operation I can think of that shows the problem
> with chart #2.)
> Thank you very much,
> carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211105/08c87aa9/attachment-0001.html>
