[gdal-dev] GeoTIFF gdalwarp puzzle
Carl Godkin
cgodkin at gmail.com
Fri Nov 5 08:09:52 PDT 2021
Partially answering myself:
I just tried again with GDAL 2.4.4 (2020/01/08) that I have on my system as
part of MS4W and it works!
I have a way forward now. I'm still going to build GDAL 3.4.0 and try it
there.
Thanks a lot,
carl
On Fri, Nov 5, 2021 at 8:02 AM Carl Godkin <cgodkin at gmail.com> wrote:
> Thanks for checking, Jukka.
> I am using GDAL 3.3.3 and get a smaller range:
> d:\gdal-3.3.3\bin64\gdalwarp.exe -t_srs epsg:4326 "Caribbean 2 VFR
> Chart.tif" caribbean_4326.tif
> Copying color table from Caribbean 2 VFR Chart.tif to new file.
> Creating output file that is 18714P x 10830L.
> Processing Caribbean 2 VFR Chart.tif [1/1] :
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> Is there a bug fix between 3.3.3 and 3.4.0 that could account for this?
> Meanwhile, I'll try to get GDAL 3.4.0 going here. Thanks,
> carl
> On Fri, Nov 5, 2021 at 7:51 AM Rahkonen Jukka (MML) <
> jukka.rahkonen at maanmittauslaitos.fi> wrote:
>> Hi,
>> Works for me on Windows with GDAL 3.4.0dev and Oct 07 2021 version of the
>> file.
>> gdalwarp -t_srs epsg:4326 "Caribbean 2 VFR Chart.tif" caribbean_4326.tif
>> Creating output file that is 18583P x 12118L.
>> The map in caribbean_4326.tif is complete.
>> -Jukka Rahkonen-
>> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Carl
>> Godkin
>> *Lähetetty:* perjantai 5. marraskuuta 2021 16.25
>> *Vastaanottaja:* gdal-dev at lists.osgeo.org
>> *Aihe:* [gdal-dev] GeoTIFF gdalwarp puzzle
>> Hi,
>> I'm working with some aviation charts and found one that behaves in a
>> puzzling manner.
>> This page
>> https://www.faa.gov/air_traffic/flight_info/aeronav/digital_products/vfr/
>> has two Caribbean VFR charts in GeoTIFF format.
>> I have been trying to run gdalwarp on "Caribbean 2 VFR Chart.tif" but I
>> only ever get a small area out of the map instead of the whole extent.
>> Specifically this command gives me just a smaller area output GeoTIFF:
>> gdalwarp -t_srs EPSG:4326 "Caribbean 2 VFR Chart.tif" out.tif --debug ON
>> I don't see anything from the debug output that explains this.
>> The other chart, "Caribbean 1 VFR Chart.tif," does not behave this way,
>> though the debug output from the same gdalwarp operation is much longer.
>> I can't see anything wrong.
>> I dragged both files into ArcGIS desktop explorer and both are displayed
>> in the proper location and in their entirety.
>> (I actually have a more elaborate workflow that works fine with chart #1
>> but this is the simplest operation I can think of that shows the problem
>> with chart #2.)
>> Thank you very much,
>> carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211105/3c6c53db/attachment.html>
