[gdal-dev] GeoTIFF gdalwarp puzzle
Carl Godkin cgodkin at gmail.com
Fri Nov 5 08:36:25 PDT 2021
...And it works fine for me in 3.4.0 as well.  Guess I just got unlucky
with the GDAL 3.3.x series!
Thanks,
carl
On Fri, Nov 5, 2021 at 8:09 AM Carl Godkin <cgodkin at gmail.com> wrote:
> Partially answering myself:
> I just tried again with GDAL 2.4.4 (2020/01/08) that I have on my system
> as part of MS4W and it works!
> I have a way forward now.  I'm still going to build GDAL 3.4.0 and try it
> there.
> Thanks a lot,
> carl
> On Fri, Nov 5, 2021 at 8:02 AM Carl Godkin <cgodkin at gmail.com> wrote:
>> Thanks for checking, Jukka.
>> I am using GDAL 3.3.3 and get a smaller range:
>> d:\gdal-3.3.3\bin64\gdalwarp.exe  -t_srs epsg:4326 "Caribbean 2 VFR
>> Chart.tif" caribbean_4326.tif
>> Copying color table from Caribbean 2 VFR Chart.tif to new file.
>> Creating output file that is 18714P x 10830L.
>> Processing Caribbean 2 VFR Chart.tif [1/1] :
>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>> Is there a bug fix between 3.3.3 and 3.4.0 that could account for this?
>> Meanwhile, I'll try to get GDAL 3.4.0 going here.  Thanks,
>> carl
>> On Fri, Nov 5, 2021 at 7:51 AM Rahkonen Jukka (MML) <
>> jukka.rahkonen at maanmittauslaitos.fi> wrote:
>>> Hi,
>>> Works for me on Windows with GDAL 3.4.0dev and Oct 07 2021 version of
>>> the file.
>>> gdalwarp -t_srs epsg:4326 "Caribbean 2 VFR Chart.tif" caribbean_4326.tif
>>> Creating output file that is 18583P x 12118L.
>>> The map in caribbean_4326.tif is complete.
>>> -Jukka Rahkonen-
>>> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Carl
>>> Godkin
>>> *Lähetetty:* perjantai 5. marraskuuta 2021 16.25
>>> *Vastaanottaja:* gdal-dev at lists.osgeo.org
>>> *Aihe:* [gdal-dev] GeoTIFF gdalwarp puzzle
>>> Hi,
>>> I'm working with some aviation charts and found one that behaves in a
>>> puzzling manner.
>>> This page
>>> https://www.faa.gov/air_traffic/flight_info/aeronav/digital_products/vfr/
>>> has two Caribbean VFR charts in GeoTIFF format.
>>> I have been trying to run gdalwarp on "Caribbean 2 VFR Chart.tif" but I
>>> only ever get a small area out of the map instead of the whole extent.
>>> Specifically this command gives me just a smaller area output GeoTIFF:
>>> gdalwarp -t_srs EPSG:4326 "Caribbean 2 VFR Chart.tif" out.tif --debug ON
>>> I don't see anything from the debug output that explains this.
>>> The other chart, "Caribbean 1 VFR Chart.tif," does not behave this way,
>>> though the debug output from the same gdalwarp operation is much longer.
>>> I can't see anything wrong.
>>> I dragged both files into ArcGIS desktop explorer and both are displayed
>>> in the proper location and in their entirety.
>>> (I actually have a more elaborate workflow that works fine with chart #1
>>> but this is the simplest operation I can think of that shows the problem
>>> with chart #2.)
>>> Thank you very much,
>>> carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211105/1c1dc70b/attachment.html>
