[gdal-dev] GeoTIFF gdalwarp puzzle
    Rahkonen Jukka (MML)
    jukka.rahkonen at maanmittauslaitos.fi
    Fri Nov  5 09:22:42 PDT 2021
I think it is not bad luck but something weird in GDAL 3.3. I tried again with version 3.3.1 from OSGeo4W and just like you I got also less pixels into output:
gdalwarp -t_srs epsg:4326 "Caribbean 2 VFR Chart.tif" caribbean_4326_2.tif
Copying color table from Caribbean 2 VFR Chart.tif to new file.
Creating output file that is 18714P x 10830L.
But this warped image is not at all the same than the one produced with GDAL 3.4. The image lacks all the legends etc. but not only those. I wonder is the TIFF file has been written in some special way on several pages or something.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Carl Godkin
Lähetetty: perjantai 5. marraskuuta 2021 17.36
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] GeoTIFF gdalwarp puzzle
...And it works fine for me in 3.4.0 as well.  Guess I just got unlucky with the GDAL 3.3.x series!
Thanks,
carl
On Fri, Nov 5, 2021 at 8:09 AM Carl Godkin <cgodkin at gmail.com<mailto:cgodkin at gmail.com>> wrote:
Partially answering myself:
I just tried again with GDAL 2.4.4 (2020/01/08) that I have on my system as part of MS4W and it works!
I have a way forward now.  I'm still going to build GDAL 3.4.0 and try it there.
Thanks a lot,
carl
On Fri, Nov 5, 2021 at 8:02 AM Carl Godkin <cgodkin at gmail.com<mailto:cgodkin at gmail.com>> wrote:
Thanks for checking, Jukka.
I am using GDAL 3.3.3 and get a smaller range:
d:\gdal-3.3.3\bin64\gdalwarp.exe  -t_srs epsg:4326 "Caribbean 2 VFR Chart.tif" caribbean_4326.tif
Processing Caribbean 2 VFR Chart.tif [1/1] : 0...10...20...30...40...50...60...70...80...90...100 - done.
Is there a bug fix between 3.3.3 and 3.4.0 that could account for this?
Meanwhile, I'll try to get GDAL 3.4.0 going here.  Thanks,
carl
On Fri, Nov 5, 2021 at 7:51 AM Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
Works for me on Windows with GDAL 3.4.0dev and Oct 07 2021 version of the file.
gdalwarp -t_srs epsg:4326 "Caribbean 2 VFR Chart.tif" caribbean_4326.tif
Creating output file that is 18583P x 12118L.
The map in caribbean_4326.tif is complete.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> Puolesta Carl Godkin
Lähetetty: perjantai 5. marraskuuta 2021 16.25
Vastaanottaja: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] GeoTIFF gdalwarp puzzle
I'm working with some aviation charts and found one that behaves in a puzzling manner.
This page https://www.faa.gov/air_traffic/flight_info/aeronav/digital_products/vfr/
has two Caribbean VFR charts in GeoTIFF format.
I have been trying to run gdalwarp on "Caribbean 2 VFR Chart.tif" but I only ever get a small area out of the map instead of the whole extent.  Specifically this command gives me just a smaller area output GeoTIFF:
gdalwarp -t_srs EPSG:4326 "Caribbean 2 VFR Chart.tif" out.tif --debug ON
I don't see anything from the debug output that explains this.
The other chart, "Caribbean 1 VFR Chart.tif," does not behave this way, though the debug output from the same gdalwarp operation is much longer.
I can't see anything wrong.
I dragged both files into ArcGIS desktop explorer and both are displayed in the proper location and in their entirety.
(I actually have a more elaborate workflow that works fine with chart #1 but this is the simplest operation I can think of that shows the problem with chart #2.)
Thank you very much,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211105/8359f8d5/attachment-0001.html>
