[gdal-dev] [EXTERNAL] Re: GDAL 3.4.0 is released
Clay, Bruce bclay at infoscitex.com
Wed Nov 10 07:32:00 PST 2021
Jeff:
  Can you add an example to the mapserver set of examples to add support for a slippy map (XYZ)?  I can not find anything that shows how to add a local slippy map directory tree to the map file.
Bruce
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Jeff McKenna <jmckenna at gatewaygeomatics.com>
Sent: Monday, November 8, 2021 12:11 PM
To: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] Re: [gdal-dev] GDAL 3.4.0 is released
All MapServer demo services (over 10+ OGC services) have been updated to
GDAL 3.4.0 : https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdemo.mapserver.org%2F&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363705518%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=p9jTVg8PKsaX899y62Oa3WIZsVN00Ita1O1nKYoVIeU%3D&reserved=0
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
https://usg02.safelinks.protection.office365.us/?url=http%3A%2F%2Fgatewaygeo.com%2F&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363705518%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=liq1maeD%2B%2B%2BnXz%2FMOg900v2GYaooSvcA6S2G06roBTY%3D&reserved=0
On 2021-11-08 9:42 a.m., Even Rouault wrote:
> Hi,
> On behalf of the GDAL/OGR development team and community, I am pleased to
> announce the release of GDAL/OGR 3.4.0. GDAL/OGR is a C++ geospatial data
> access library for raster and vector file formats, databases and web
> services.
> It includes bindings for several languages, and a variety of command line
> tools.
>     https://usg02.safelinks.protection.office365.us/?url=http%3A%2F%2Fgdal.org%2F&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363705518%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=uyFxegtdVqazi%2BpUzHW6Y2vx5UVrwn97Xe4jxfgr9X0%3D&reserved=0
> The 3.4.0 release is a new feature release with the following highlights:
> * [RFC 81](https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fgdal.org%2Fdevelopment%2Frfc%2Frfc81_coordinate_epoch.html&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363705518%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=IgtdgnC%2FtHwYr4jd5f2yGKj6hOxsgc6v1irtuDL30Hc%3D&reserved=0):
>    Support for coordinate epochs in geospatial formats.
>    Implemented in FlatGeoBuf, GeoPackage, MEM, VRT
> * New GDAL drivers:
>    - [Zarr](https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fgdal.org%2Fdrivers%2Fraster%2Fzarr.html&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363715511%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=fv3Igmm8lc5xOStbrBonSoDQSboomAbiyWVKDwEpEvo%3D&reserved=0):
>      read/write support for ZarrV2 (and experimental V3), using 2D
> classic raster
>      API or multidimensional API:
>    - [STACIT](https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fgdal.org%2Fdrivers%2Fraster%2Fstacit.html&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363715511%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=rYNT%2FG8BizGyNgTZiSPoGY%2Bwj1hU%2B%2FZHGPBZkXB8hRQ%3D&reserved=0):
>      Spatio-Temporal Asset Catalog Items as virtual mosaics
> * Other improvements:
>    - number of enhancements in file system operations of /vsigs/
>    - NITF: additions to comply with NITF Version 2.1 Commercial Dataset
>      Requirements Document (NCDRD)
>    - ODBC and PGeo: multiple fixes and improvements
>    - SAFE (Sentinel1): multiple improvements related to SLC/calibration
> (change
>      subdataset naming)
>    - multidimensional API: caching, and other improvements
> * Code linting and security fixes
> * MDB driver (Java based) mark as deprecated. Planned for removal for
> GDAL 3.5.
>    ODBC driver is the preferred solution (with up-to-date MDBTools
> library on
>    non-Windows platforms)
> * Writing side of Tiger driver deprecated and will be removed in GDAL 3.5
> * Remainder: DODS, JPEG2000(Jasper), JPEGLS, MG4LIDAR, FUJIBAS, IDA,
> INGR and
>    vector driver ARCGEN, ArcObjects, CLOUDANT, COUCHDB, DB2, DODS, FME,
> GEOMEDIA,
>    GTM, INGRES, MONGODB, REC, WALK are planned for removal in GDAL 3.5.
> As well
>    as Perl bindings
> More complete information on the new features and fixes in the 3.4.0
> release can be found at:
>    https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgdal%2Fblob%2Fv3.4.0%2Fgdal%2FNEWS.md&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363715511%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=GYtBAmSoLG57GdgmjmvNGuf8HB4U7p%2FIfuO56%2FlP9Zw%3D&reserved=0
> The release can be downloaded from:
>    * https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdownload.osgeo.org%2Fgdal%2F3.4.0%2Fgdal340.zip&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363715511%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=TOQgqqzeRBJg%2FOVuJG%2BidqKrM68nA8WepR3X0fT9d30%3D&reserved=0 - source as a zip
>    * https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdownload.osgeo.org%2Fgdal%2F3.4.0%2Fgdal-3.4.0.tar.gz&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363715511%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=3v4xfi7%2FC473ZEwO0rJFtM8oTrXxMyYbE40t3dLMMVI%3D&reserved=0 - source as
> .tar.gz
>    * https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdownload.osgeo.org%2Fgdal%2F3.4.0%2Fgdal-3.4.0.tar.xz&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363715511%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=TV7J%2B6xRtvwa8UP0MSpi%2FoM2%2Fwcnc5tLwiJPaMPP%2F0o%3D&reserved=0 - source as
> .tar.xz
>    * https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdownload.osgeo.org%2Fgdal%2F3.4.0%2Fgdal-grass-3.4.0.tar.gz&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363715511%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=HkD037FzWFo0iOMdhKXz5dro2azZG1R0SCABq29s4aM%3D&reserved=0 -
> GDAL-GRASS plugin
>    * https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdownload.osgeo.org%2Fgdal%2F3.4.0%2Fgdalautotest-3.4.0.tar.gz&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363715511%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=snTmAp%2B2UQ8FWIBz8WyrG%2BG2FMMolpKg0NcT4lDt8bc%3D&reserved=0 -
> test suite
>    * https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdownload.osgeo.org%2Fgdal%2F3.4.0%2Fgdal340doc.zip&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363715511%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=DUQgZmP5cKogUNgP9J6nom6gU6apep6kK4doJAey9ws%3D&reserved=0 -
> documentation / website
> Best regards,
> Even
gdal-dev mailing list
https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=04%7C01%7Cbclay%40infoscitex.com%7C52f6b9a5246f457b13c408d9a2dae757%7C3430c5de5e6f4f9d9d9690e985038b58%7C0%7C0%7C637719885363715511%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=ofPDNbmZ91VnQOSXqj%2Fze4PFXn0LiKBlAtPk5X1VnKI%3D&reserved=0
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211110/a7db5126/attachment-0001.html>
