[gdal-dev] WKID not set for reprojectionfrom WGS84 to GDA2020
Abhay Duvvuri aduv1609 at gmail.com
Mon Nov 8 05:59:35 PST 2021
I am trying to reproject ESRI file geodatabase data from WGS84 (3857) to
GDA2020 (7844) with "FileGDB" driver option. The data is reprojected but
WKID is not set.
ogr2ogr tool is being used to reproject data.
Please let me know what can be done here.
Also, is there a docker image readily available with FileGDB configured. I
am able to build an image by following the steps from
https://github.com/OSGeo/gdal/tree/master/docker but wanted to check if
there is an image readily available.
Any advice here is greatly appreciated.
Thanks and regards,
Abhay
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211109/a407068c/attachment.html>
