[gdal-dev] georeferenced but not georeferenced?
Matt.Wilkie at yukon.ca Matt.Wilkie at yukon.ca
Wed Nov 10 13:03:48 PST 2021
Hi all,
I'm creating images from SPOT6/7 archive DIMAP format. The resulting images display in the correct position in the world when combined with other sources, however all the usual tools say the images have no georeferencing.
* If the images have no georeferencing how do ArcMap/Pro and Qgis know to put them in the right place?
* How can I convert whatever-this-is into proper georeferencing so that other tools know how to handle them too?
Attached is a sample image.  It was created with (on one line):
    gdal_translate  -outsize 100 0
    -co compress=zstd -co predictor=yes -co level=17 -co bigtiff=yes -of cog
    .\path\to\IMG_SPOT6_MS_001_A\DIM_SPOT6_MS_201609082010410_SEN_1.XML
    source_tiny.tif
The biggest problem this causes me at the moment is that gdal_pansharpen.py output does not have any kind of goereferencing, and I can't use old faithfuls like listgeo, geotiffcp, or gdalcopyproj.py to copy the coordinate system across.
thanks in advance for your thoughts,
Matt Wilkie
Geomatics Developer & Administrator
Environment | Technology, Innovation and Mapping
T 867-667-8133 | Yukon.ca
Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away.
Type: image/tiff
Desc: source_tiny.tif
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211110/00bb6a71/attachment-0001.tif>
