[gdal-dev] georeferenced but not georeferenced?
Even Rouault
even.rouault at spatialys.com
Wed Nov 10 13:15:57 PST 2021
Le 10/11/2021 à 22:03, Matt.Wilkie at yukon.ca a écrit :
> Hi all,
> I'm creating images from SPOT6/7 archive DIMAP format. The resulting images display in the correct position in the world when combined with other sources, however all the usual tools say the images have no georeferencing.
> * If the images have no georeferencing how do ArcMap/Pro and Qgis know to put them in the right place?
Those images have RPC. You can see RPC information with gdalinfo in the
"RPC Metadata" section
listeo/geotiffcp and a number of utilities are not RPC aware. But
gdalwarp is.
> * How can I convert whatever-this-is into proper georeferencing so that other tools know how to handle them too?
You can use gdalwarp to orthorectify them. You should generally specify
-to RPC_DEM=some_dem_with_elevation_as_ellipsoidal_heights or -to
RPC_HEIGHT=ellipsoidal_height. See
https://gdal.org/api/gdal_alg.html?highlight=rpc_dem
> Attached is a sample image. It was created with (on one line):
> gdal_translate -outsize 100 0
> -co compress=zstd -co predictor=yes -co level=17 -co bigtiff=yes -of cog
> .\path\to\IMG_SPOT6_MS_001_A\DIM_SPOT6_MS_201609082010410_SEN_1.XML
> source_tiny.tif
> The biggest problem this causes me at the moment is that gdal_pansharpen.py output does not have any kind of goereferencing, and I can't use old faithfuls like listgeo, geotiffcp, or gdalcopyproj.py to copy the coordinate system across.
> thanks in advance for your thoughts,
> Matt Wilkie
> Geomatics Developer & Administrator
> Environment | Technology, Innovation and Mapping
> T 867-667-8133 | Yukon.ca
> Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211110/5162b589/attachment.html>
