[gdal-dev] Mosaicing using GDAL Wrap / Translate
Lars Schylberg
lars.schylberg at blixtmail.se
Thu Nov 11 10:07:30 PST 2021
Sorry, but I am a linux person and it usually takes me 3 times longer to
write python.
There is the python program gdal_retile.py, but if I remember, it didn't
handle my use case the way I wanted it.
/Lars S.
Den 2021-11-11 kl. 17:54, skrev Lorenzo Di Giacomo:
> I guess it'll do the trick but a python script would be appreciated
> instead of rewriting it, if someone has it would be helpful, thanks!
> Il giorno gio 11 nov 2021 alle ore 17:22 <lars.schylberg at blixtmail.se>
> ha scritto:
> Hi
> I talked about this at the foss4g 2 years ago and shared a bash
> script where I do exactly what you are asking for. I don't know if
> you consider it to be easy, but
> the example is this script:
> https://gist.github.com/LarsSchy/9ecb31eb964dd83820c139b2f2769a7c
> Look at the function: retile_with_mask() in the script. The script
> is doing other things as well like creating a tile index for
> Mapserver usage and trimming the tiles from nodata parts.
> Have fun / Lars S.
> 11 november 2021 kl. 15:46, "Lorenzo Di Giacomo"
> <loridigia at gmail.com
> <mailto:loridigia at gmail.com?to=%22Lorenzo%20Di%20Giacomo%22%20%3Cloridigia at gmail.com%3E>>
> skrev:
> Hi, i can't find a simple way (not to choose the cut
> coordinates manually) in order to crop an entire raster image
> into N images given a fixed size of pixel, how can this be
> achieved? Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211111/4232a9f3/attachment.html>
