[gdal-dev] Mosaicing using GDAL Wrap / Translate
Lorenzo Di Giacomo
loridigia at gmail.com
Thu Nov 11 08:54:18 PST 2021
I guess it'll do the trick but a python script would be appreciated instead
of rewriting it, if someone has it would be helpful, thanks!
Il giorno gio 11 nov 2021 alle ore 17:22 <lars.schylberg at blixtmail.se> ha
scritto:
> Hi
> I talked about this at the foss4g 2 years ago and shared a bash script
> where I do exactly what you are asking for. I don't know if you consider it
> to be easy, but
> the example is this script:
> https://gist.github.com/LarsSchy/9ecb31eb964dd83820c139b2f2769a7c
> Look at the function: retile_with_mask() in the script. The script is
> doing other things as well like creating a tile index for Mapserver usage
> and trimming the tiles from nodata parts.
> Have fun / Lars S.
> 11 november 2021 kl. 15:46, "Lorenzo Di Giacomo" <loridigia at gmail.com
> <loridigia at gmail.com?to=%22Lorenzo%20Di%20Giacomo%22%20%3Cloridigia at gmail.com%3E>>
> skrev:
> Hi, i can't find a simple way (not to choose the cut coordinates manually)
> in order to crop an entire raster image into N images given a fixed size of
> pixel, how can this be achieved? Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211111/035dcce3/attachment-0001.html>
