[gdal-dev] gdal2tiles EPSG:3857 Out of Memory
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Nov 15 01:53:23 PST 2021
GDAL version 2.4.0 is not supported any more. I had a try with 3857.pdf with GDAL 3.1.7 and Python 3.7 by running
gdal2tiles -r average -z 12-18 3857.pdf
Process took 15 seconds with my Windows laptop. I guessed you meant -r average because -t antialias does not exist to my knowledge.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta pepijn.szeker at tractebel.engie.com
Lähetetty: maanantai 15. marraskuuta 2021 10.44
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] gdal2tiles EPSG:3857 Out of Memory
Dear all,
I assume this belongs to this mailing list instead of the GitHub Issues.
Find attached 2 pdf (plots from QGIS) of the same area, but plotted in EPSG:3857 and EPSG: 31370. (if attachments are not allowed: there is nothing special about what is on the pdf: it's simply 1 styled vector line and 1 labelled vector point).
The pdf were checked with gdalinfo. Except for the CRS, I don't notice anything peculiar.
Notice this is still gdal 2.4.0. Due to company restrictions gdal 3 tiling runs awfully slow. Maybe the problem is however known to any of you.
Windows 10, python 2.7
Task:
* Running gdal2tiles on the pdf, with parameters:
* -r antialias
* -z 12-18
* -processes=30
Problem:
* EPSG 31370 runs fine, but due to reprojection labels are slightly rotated
* EPSG 3857 plot would fix the above, but for some reason gdal2tiles will not run on this. It barely starts. After waiting long enough error codes start showing in the CMD. The errors contain easily hundreds of line.
See below a small excerpt:
Out of memory
Out of memory
0Out of memory
Out of memory
Out of memory
Out of memory
Out of memory
Out of memory
ERROR 2: Cannot allocate result buffer
ERROR 2: memdataset.cpp, 1541: cannot allocate 1x1048576 bytes
Out of memory
Out of memory
Out of memory
ERROR 1: Bitmap decoded size (1x1) doesn't match raster size (1024x1024)
ERROR 1: C:\Users\MyUser\AppData\Local\Temp\tmpj7_ghurm\e4a8f99b-98d8-4425-b6d1-6540ff951385.vrt, band 2: IReadBlock failed at X offset 5, Y offset 2: Bitmap decoded size (1x1) doesn't match raster size (1024x1024)
.Out of memory
Out of memory
Out of memory
Out of memory
Out of memory
Out of memory
Out of memory
ERROR 1: C:\Users\MyUser\AppData\Local\Temp\tmpj7_ghurm\e4a8f99b-98d8-4425-b6d1-6540ff951385.vrt, band 1: IReadBlock failed at X offset 1, Y offset 4
10Out of memory
Out of memory
Out of memory
Out of memory
Out of memory
Out of memory
Any pointers?
Met vriendelijke groeten,
Pepijn SZEKÉR
Engineer - Transport Infrastructure
<mailto:pepijn.szeker at tractebel.engie.com>M +32 499 61 25 58
[cid:image001.png at 01D7DA16.53955430]
tractebel-engie.com
<http://tractebel-engie.com/>
TRACTEBEL ENGINEERING S.A.
Ilgatlaan 23
3500 Hasselt - BELGIUM
VAT BE 0412 639 681 RPR/RPM Brussels
Please consider the environment before printing this document.
[cid:image003.png at 01D7DA16.53955430]<https://www.linkedin.com/company/tractebel-engie-group> [cid:image004.png at 01D7DA16.53955430] <https://twitter.com/Tractebel> [cid:image005.png at 01D7DA16.53955430] <https://www.instagram.com/tractebel_company> [cid:image006.png at 01D7DA16.53955430] <https://www.youtube.com/tractebelengie>
TRACTEBEL Privacy Statement: https://tractebel-engie.com/en/data-privacy
ENGIE Mail Disclaimer: http://www.engie.com/disclaimer/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211115/fe562aea/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211115/fe562aea/attachment-0006.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211115/fe562aea/attachment-0007.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211115/fe562aea/attachment-0008.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211115/fe562aea/attachment-0009.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211115/fe562aea/attachment-0010.png>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211115/fe562aea/attachment-0011.png>
