[gdal-dev] Polar stereographic projection invalid definition ?
Rousseau Lambert,Louis-Philippe (ECCC)
louis-philippe.rousseaulambert at ec.gc.ca
Mon Nov 15 06:25:14 PST 2021
Hi all,
I have an issue with a polar stereographic projection definition.
Context: I tried to open a NetCDF files in QGIS and with GDAL and it
failed with:
* Gdal:/ERROR 1: PROJ: proj_as_proj_string: Unsupported conversion
method: Polar_Stereographic/
* Qgis:/WARNING Could not reproject layer extent: Could not transform
bounding box to taret CRS
The projection fails with the previous error for both gdal and proj
versions:
* GDAL 3.1.3, 3.3.0
* PROJ 7.2.0, 8.01
Test files (really any files in the folder will have the same behavior):
* https://dd.weather.gc.ca/model_giops/netcdf/polar_stereographic/2d/00/003/CMC_giops_votemper_depth_0.5_ps5km60N_3h-mean_*{YYYYMMDDHH}*_P003.nc
I tried opening the files with an older gdal/proj version and it worked
fine:
* GDAL: |2.4.4, released 2020/01/08|
* PROJ: Rel. 4.8.0, 6 March 2012
Here is the projection definition I got: /+proj=stere +lat_0=90
+lat_ts=59.99993768695209 +lon_0=-100 +k=0.93301243 +x_0=4245000
+y_0=5295000 +a=6371229 +b=6371229 +units=m +no_defs/
When I tried adding the projection manually in Qgis (3.20), I got the
following error message:
/This proj projection definition is not valid://
//proj_create: lat_ts != lat_0 and k != 1 not supported for Polar
Stereographic./
Should the projection definition be updated in the NetCDF files if this
really is not a supported projection definition anymore, or is this a
bug in gdal?
If this looks like a bug to you, let me know, I will open an issue on
the gdal repo.
Thanks!
LP
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211115/3aa4b6c9/attachment-0001.html>
