[gdal-dev] Intermittent memory-corruption crashes in GRIB2 import
Even Rouault even.rouault at spatialys.com
Mon Nov 15 04:59:02 PST 2021
Simon,
unfortunately there are a number of places in the degrib library which
aren't thread-safe, and you just spotted that the errSprintf() routine
was one of them. I've queued a fix for that in
https://github.com/OSGeo/gdal/pull/4830. Could you try it ?
Regarding gdal_translate performance, this is related to something I
mentioned recently (not sure to whom), but you'll get much better
performance if you add -co INTERLEAVE=BAND, so that the output GeoTIFF
is written band after band, to match the most performant access pattern
for reading GRIB files.
Even
Le 15/11/2021 à 01:32, Simon Eves a écrit :
> We have recently implemented a geo raster importer, and all seems
> fine, except that we hit an issue with a particular GRIB2 file from
> the NOAA website, where we get an inconsistent crash inside GDAL after
> a few hundred scanlines.
> We have seen two different crashes inside GDAL, and a third in one of
> our code paths, but given that there is a memory corruption, the
> latter is perhaps unsurprising.
> All crashes report "double free or corruption (fasttop)".
> We are multi-threading the reading, but using a OGRDataSource per
> thread. The child threads are only calling GetRasterBand(),
> GetRasterDataType() and RasterIO() and only one one band at a time.
> The GRIB2 file is 103MB with 73 Float64 bands, but only 2345x1597
> "pixels".
> We tried converting the file to GeoTIFF with gdal_translate (no
> options, just in and out) and it took 28 minutes (on a ~2017 i7 quad
> 4.2), which is surprising, as we have other GRIB2 files (between 2 and
> 12MB) which convert "instantly". The resulting GeoTIFF is much bigger
> (21x) but seems to import reliably, has basically the same schema (as
> reported by gdalinfo) and results in the same data when imported into
> our system.
> We only get the crash occasionally, and have only been able to trap it
> in the Debugger a couple of times, with nothing obviously wrong.
> Here is a link to the GRIB2 file in question:
> https://drive.google.com/file/d/12Fo6jnIhxzCvnSsup9n0kHVKy9lrHD2l/view?usp=sharing
> <https://drive.google.com/file/d/12Fo6jnIhxzCvnSsup9n0kHVKy9lrHD2l/view?usp=sharing>
> Attached is the most common stack trace.
> With a DEBUG build of GDAL, looks like it's crashing trying to do a
> realloc() on "buffer" which is NULL, although that is supposedly a
> copy of "&errBuffer" at the frame above which seems fine.
> Gonna try robustifying that code and see what happens...
> This is all with GDAL 3.2.2 on Ubuntu 20.04 LTS with GCC 9.
> <http://www.omnisci.com/>
> Simon Eves
> Senior Graphics Engineer, Rendering Group
> 100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
> Email: simon.eves at omnisci.com <mailto:simon.eves at omnisci.com> | Cell:
> +1 (415) 902-1996
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211115/aa49dee9/attachment.html>
