[gdal-dev] Intermittent memory-corruption crashes in GRIB2 import
Simon Eves simon.eves at omnisci.com
Tue Nov 16 12:57:08 PST 2021
Hi Even,
Sorry for the slow response. I was out yesterday and this morning. Testing
your fix now.
Simon
On Mon, Nov 15, 2021 at 4:59 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Simon,
> unfortunately there are a number of places in the degrib library which
> aren't thread-safe, and you just spotted that the errSprintf() routine was
> one of them. I've queued a fix for that in
> https://github.com/OSGeo/gdal/pull/4830. Could you try it ?
> Regarding gdal_translate performance, this is related to something I
> mentioned recently (not sure to whom), but you'll get much better
> performance if you add -co INTERLEAVE=BAND, so that the output GeoTIFF is
> written band after band, to match the most performant access pattern for
> reading GRIB files.
> Even
> Le 15/11/2021 à 01:32, Simon Eves a écrit :
> We have recently implemented a geo raster importer, and all seems fine,
> except that we hit an issue with a particular GRIB2 file from the NOAA
> website, where we get an inconsistent crash inside GDAL after a few hundred
> scanlines.
> We have seen two different crashes inside GDAL, and a third in one of our
> code paths, but given that there is a memory corruption, the latter is
> perhaps unsurprising.
> All crashes report "double free or corruption (fasttop)".
> We are multi-threading the reading, but using a OGRDataSource per thread.
> The child threads are only calling GetRasterBand(), GetRasterDataType() and
> RasterIO() and only one one band at a time.
> The GRIB2 file is 103MB with 73 Float64 bands, but only 2345x1597 "pixels".
> We tried converting the file to GeoTIFF with gdal_translate (no options,
> just in and out) and it took 28 minutes (on a ~2017 i7 quad 4.2), which is
> surprising, as we have other GRIB2 files (between 2 and 12MB) which convert
> "instantly". The resulting GeoTIFF is much bigger (21x) but seems to import
> reliably, has basically the same schema (as reported by gdalinfo) and
> results in the same data when imported into our system.
> We only get the crash occasionally, and have only been able to trap it in
> the Debugger a couple of times, with nothing obviously wrong.
> Here is a link to the GRIB2 file in question:
> https://drive.google.com/file/d/12Fo6jnIhxzCvnSsup9n0kHVKy9lrHD2l/view?usp=sharing
> Attached is the most common stack trace.
> With a DEBUG build of GDAL, looks like it's crashing trying to do a
> realloc() on "buffer" which is NULL, although that is supposedly a copy of
> "&errBuffer" at the frame above which seems fine.
> Gonna try robustifying that code and see what happens...
> This is all with GDAL 3.2.2 on Ubuntu 20.04 LTS with GCC 9.
> <http://www.omnisci.com/>
> Simon Eves
> Senior Graphics Engineer, Rendering Group
> 100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
> Email: simon.eves at omnisci.com | Cell:  +1 (415) 902-1996
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Simon Eves
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211116/7594f47b/attachment.html>
