[gdal-dev] Intermittent memory-corruption crashes in GRIB2 import
Simon Eves
simon.eves at omnisci.com
Tue Nov 16 15:21:11 PST 2021
Hi Even,
Thank you very much for the quick and plausible fix. It certainly seems to
resolve the issue on my machine. I'm sending a build to my colleague to
test it on his Threadripper, as he was the first one to hit it.
Looks like you have merged this into master and into the 3.4 release
branch. Can we assume, therefore, that it will be in 3.4.1, which
appears to be scheduled for the end of December?
Simon
On Tue, Nov 16, 2021 at 12:57 PM Simon Eves <simon.eves at omnisci.com> wrote:
> Hi Even,
> Sorry for the slow response. I was out yesterday and this morning. Testing
> your fix now.
> Simon
> On Mon, Nov 15, 2021 at 4:59 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Simon,
>> unfortunately there are a number of places in the degrib library which
>> aren't thread-safe, and you just spotted that the errSprintf() routine was
>> one of them. I've queued a fix for that in
>> https://github.com/OSGeo/gdal/pull/4830. Could you try it ?
>> Regarding gdal_translate performance, this is related to something I
>> mentioned recently (not sure to whom), but you'll get much better
>> performance if you add -co INTERLEAVE=BAND, so that the output GeoTIFF is
>> written band after band, to match the most performant access pattern for
>> reading GRIB files.
>> Even
>> Le 15/11/2021 à 01:32, Simon Eves a écrit :
>> We have recently implemented a geo raster importer, and all seems fine,
>> except that we hit an issue with a particular GRIB2 file from the NOAA
>> website, where we get an inconsistent crash inside GDAL after a few hundred
>> scanlines.
>> We have seen two different crashes inside GDAL, and a third in one of our
>> code paths, but given that there is a memory corruption, the latter is
>> perhaps unsurprising.
>> All crashes report "double free or corruption (fasttop)".
>> We are multi-threading the reading, but using a OGRDataSource per thread.
>> The child threads are only calling GetRasterBand(), GetRasterDataType() and
>> RasterIO() and only one one band at a time.
>> The GRIB2 file is 103MB with 73 Float64 bands, but only 2345x1597
>> "pixels".
>> We tried converting the file to GeoTIFF with gdal_translate (no options,
>> just in and out) and it took 28 minutes (on a ~2017 i7 quad 4.2), which is
>> surprising, as we have other GRIB2 files (between 2 and 12MB) which convert
>> "instantly". The resulting GeoTIFF is much bigger (21x) but seems to import
>> reliably, has basically the same schema (as reported by gdalinfo) and
>> results in the same data when imported into our system.
>> We only get the crash occasionally, and have only been able to trap it in
>> the Debugger a couple of times, with nothing obviously wrong.
>> Here is a link to the GRIB2 file in question:
>> https://drive.google.com/file/d/12Fo6jnIhxzCvnSsup9n0kHVKy9lrHD2l/view?usp=sharing
>> Attached is the most common stack trace.
>> With a DEBUG build of GDAL, looks like it's crashing trying to do a
>> realloc() on "buffer" which is NULL, although that is supposedly a copy of
>> "&errBuffer" at the frame above which seems fine.
>> Gonna try robustifying that code and see what happens...
>> This is all with GDAL 3.2.2 on Ubuntu 20.04 LTS with GCC 9.
>> <http://www.omnisci.com/>
>> Simon Eves
>> Senior Graphics Engineer, Rendering Group
>> 100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
>> Email: simon.eves at omnisci.com | Cell: +1 (415) 902-1996
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
> Simon Eves
Simon Eves
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211116/cf0b71b2/attachment-0001.html>
