[gdal-dev] Intermittent memory-corruption crashes in GRIB2 import
Even Rouault
even.rouault at spatialys.com
Tue Nov 16 15:27:22 PST 2021
Le 17/11/2021 à 00:21, Simon Eves a écrit :
> Hi Even,
> Thank you very much for the quick and plausible fix. It certainly
> seems to resolve the issue on my machine. I'm sending a build to my
> colleague to test it on his Threadripper, as he was the first one to
> hit it.
> Looks like you have merged this into master and into the 3.4 release
> branch. Can we assume, therefore, that it will be in 3.4.1, which
> appears to be scheduled for the end of December?
your inference is correct :-)
> Simon
> On Tue, Nov 16, 2021 at 12:57 PM Simon Eves <simon.eves at omnisci.com
> <mailto:simon.eves at omnisci.com>> wrote:
> Hi Even,
> Sorry for the slow response. I was out yesterday and this morning.
> Testing your fix now.
> Simon
> On Mon, Nov 15, 2021 at 4:59 AM Even Rouault
> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>>
> wrote:
> Simon,
> unfortunately there are a number of places in the degrib
> library which aren't thread-safe, and you just spotted that
> the errSprintf() routine was one of them. I've queued a fix
> for that in https://github.com/OSGeo/gdal/pull/4830
> <https://github.com/OSGeo/gdal/pull/4830>. Could you try it ?
> Regarding gdal_translate performance, this is related to
> something I mentioned recently (not sure to whom), but you'll
> get much better performance if you add -co INTERLEAVE=BAND, so
> that the output GeoTIFF is written band after band, to match
> the most performant access pattern for reading GRIB files.
> Even
> Le 15/11/2021 à 01:32, Simon Eves a écrit :
>> We have recently implemented a geo raster importer, and all
>> seems fine, except that we hit an issue with a particular
>> GRIB2 file from the NOAA website, where we get an
>> inconsistent crash inside GDAL after a few hundred scanlines.
>> We have seen two different crashes inside GDAL, and a third
>> in one of our code paths, but given that there is a memory
>> corruption, the latter is perhaps unsurprising.
>> All crashes report "double free or corruption (fasttop)".
>> We are multi-threading the reading, but using a OGRDataSource
>> per thread. The child threads are only
>> calling GetRasterBand(), GetRasterDataType() and RasterIO()
>> and only one one band at a time.
>> The GRIB2 file is 103MB with 73 Float64 bands, but only
>> 2345x1597 "pixels".
>> We tried converting the file to GeoTIFF with gdal_translate
>> (no options, just in and out) and it took 28 minutes (on a
>> ~2017 i7 quad 4.2), which is surprising, as we have other
>> GRIB2 files (between 2 and 12MB) which convert "instantly".
>> The resulting GeoTIFF is much bigger (21x) but seems to
>> import reliably, has basically the same schema (as reported
>> by gdalinfo) and results in the same data when imported into
>> our system.
>> We only get the crash occasionally, and have only been able
>> to trap it in the Debugger a couple of times, with nothing
>> obviously wrong.
>> Here is a link to the GRIB2 file in question:
>> https://drive.google.com/file/d/12Fo6jnIhxzCvnSsup9n0kHVKy9lrHD2l/view?usp=sharing
>> <https://drive.google.com/file/d/12Fo6jnIhxzCvnSsup9n0kHVKy9lrHD2l/view?usp=sharing>
>> Attached is the most common stack trace.
>> With a DEBUG build of GDAL, looks like it's crashing trying
>> to do a realloc() on "buffer" which is NULL, although that is
>> supposedly a copy of "&errBuffer" at the frame above which
>> seems fine.
>> Gonna try robustifying that code and see what happens...
>> This is all with GDAL 3.2.2 on Ubuntu 20.04 LTS with GCC 9.
>> <http://www.omnisci.com/>
>> Simon Eves
>> Senior Graphics Engineer, Rendering Group
>> 100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
>> Email: simon.eves at omnisci.com
>> <mailto:simon.eves at omnisci.com> | Cell: +1 (415) 902-1996
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> http://www.spatialys.com <http://www.spatialys.com>
> My software is free, but my time generally not.
> Simon Eves
> Email: simon.eves at omnisci.com <mailto:simon.eves at omnisci.com> |
> Simon Eves
> Email: simon.eves at omnisci.com <mailto:simon.eves at omnisci.com> | Cell:
> +1 (415) 902-1996
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211117/d84d6e54/attachment-0001.html>
