[gdal-dev] setting MAX_Z_ERROR on overviews compressed with LERC_DEFLATE
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Thu Nov 18 04:41:27 PST 2021
I made some tests with an 8 bit RGB image.
First observation was that gdaladdo supports lerc_deflate (even it is not documented), but it does not support “MAX_Z_ERROR”. This yields same sized ovr file with or without max_z_error.
gdaladdo -ro lerc_def2.tif --config compress_overview lerc_deflate --config MAX_Z_ERROR 10
Another observation was that this option would really save some disk space. I compressed the lossless ovr file with gdal_translate by using -co max_z_error=10 and file sizes were:
source tiff: 432 072 372 bytes
lecr_deflate cog without overviews: 311 258 085 bytes
lossless lerc_deflate overviews: 118 954 009 bytes
lerc_deflare overviews with z_error=10: 52 400 583 bytes
For comparison even not relevant to original question about 32 bit data
jpeg-ycbcr overviews with default quality: 14 481 967 bytes
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Duarte Carreira
Lähetetty: torstai 18. marraskuuta 2021 13.45
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] setting MAX_Z_ERROR on overviews compressed with LERC_DEFLATE
Hi there.
I am looking into compressing overviews for a DEM, with LERC_DEFLATE and it works. But I'm trying to set the precision loss and get better compression, since for overviews I don't really care that much.
Ok, so the question is how to set the MAX_Z_ERROR for overviews compressed with LERC_DEFLATE?
More context:
My reasoning is to compress losslessly the dem with deflate predictor 3, and then compress "lossly"  the overviews with lerc_deflate.
Since this is 32bit dataset, I can't use jpeg on the overviews.
Thanks in advance.
Duarte
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211118/887b5263/attachment-0001.html>
