[gdal-dev] Black borders after reprojection GDAL_WARP
Even Rouault
even.rouault at spatialys.com
Thu Nov 18 06:46:23 PST 2021
Black borders are completely expected: reprojection changes the geometry
of the image.
That said, if the area of interest is sufficiently small and the
geometry change being approximatively an affine transformation, you can
try https://gdal.org/programs/gdalmove.html instead of gdalwarp to only
alter the georeferencing information and not touch pixel values at all.
Even
Le 18/11/2021 à 15:34, Lorenzo Di Giacomo a écrit :
> Hi Carl, thanks for your reply, i noticed that it happens even if i
> just reproject the image, without cutting.
> Of course the dstalpha works, but it increases the size of the image
> and it changes its nature (adding another band) since this operation
> is an intermediate operation the resulting image can't be different
> from the original, just reporojected.
> Il giorno gio 18 nov 2021 alle ore 14:11 Carl Godkin
> <cgodkin at gmail.com <mailto:cgodkin at gmail.com>> ha scritto:
> Hi Lorenzo,
> I have faced this and there are two things to consider.
> First, you can specify the georeferenced extents _and_ the SRS of
> the extents using something like this:
> gdalwarp -t_srs EPSG:3857 \
> -te_srs EPSG:4326 -te -109 32 -102 36 \
> input.tif output.tif
> Note that I'm warping to one coordinate system but trimming based
> on another one. Is it possible that your black boundary is due to
> trimming in the wrong coordinate system? For instance, if your
> input map is projected but the boundary of the map consists of
> parallels of latitude or meridians of longitude, then you could
> use something like the above. (You can actually get even fancier
> by trimming with polygons too; see this example for inspiration:
> https://gis.stackexchange.com/questions/45053/gdalwarp-cutline-along-with-shapefile
> <https://gis.stackexchange.com/questions/45053/gdalwarp-cutline-along-with-shapefile>
> Second, recognize that the output will always be a rectangle in
> the output SRS. If the black border is due to "no data" areas
> outside the input map's extent appearing in the output map, then
> you can use -dstalpha ("Create an output alpha band to identify
> nodata (unset/transparent) pixels.") to mark the output pixels
> that shouldn't be part of the map. Basically your black pixels
> become transparent in this case.
> I hope that helps,
> carl
> On Wed, Nov 17, 2021 at 8:11 AM Lorenzo Di Giacomo
> <loridigia at gmail.com <mailto:loridigia at gmail.com>> wrote:
> Hi all, i have a question, how is it possible to avoid black
> borders after reprojection with "gdal_warp" ?
> Basically i have an image that is little rotated, when i
> reprojected from 32632 to 4326 the resulting image has black
> borders more or less tight depending on the rotation.
> I saw i can change the colors of those no_data (using
> -dstnodata) but how can i do if i dont want it at all? Adding
> another band result in a size increase, that i don't want either.
> Thanks !!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211118/57c5c57e/attachment-0001.html>
