[gdal-dev] GDALWMS - error: TCP connection reset by peer
Roman Breitfuss-Schiffer
roman.schiffer at gmail.com
Fri Nov 19 00:18:25 PST 2021
Dear Jukka!
Thanks for your answer! I think I'm gonna follow that road you suggested.
We have been thinking a lot and I was just wondering if there could be
some GDAL configuration which could cause that behaviour? For example
the value for <MaxConnections> in the WMS XML file? Or if more
applications are accessing the same WMS XML at the same time which is
theoretically possible in our case.
Best regards
Roman
Am 18.11.2021 um 12:12 schrieb Rahkonen Jukka (MML):
> Hi,
> It seems that the WMS server is closing the door and there is nothing
> else to do on the GDAL side except to try again later. Contact the WMS
> service maintainer and report your troubles. They may be able to
> provide you a more reliable service especially if you are ready to pay
> for it.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Roman Breitfuss-Schiffer
> *Lähetetty:* torstai 18. marraskuuta 2021 11.59
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] GDALWMS - error: TCP connection reset by peer
> Dear all!
> We are running a Python application an a linux distribution (RedHat)
> which creates clips in MBTILES format from a WMS. We are using the
> Python-API and are basically doing something like this:
> src_ds = gdal.Warp(
> tmp_file,
> ds_in,
> format='GTiff',
> outputBounds=[bbox[0], bbox[2], bbox[1], bbox[3]],
> dstSRS=output_srs,
> ds_out = gdal.Translate(
> out_filepath,
> src_ds,
> format='MBTILES',
> creationOptions=creation_options,
> The application throughs an error from time to time since a few days.
> We couldn't figure out a pattern yet and therefore we are also not
> able to reproduce the error. The error is the following:
> Mon Nov 15 13:48:13 2021: CPLError: GDALWMS: Unable to download block
> 2765, 602.
> URL: TCP connection reset by peer
> HTTP status code: 0, error: TCP connection reset by peer.
> Add the HTTP status code to <ZeroBlockHttpCodes> to ignore this error
> (see http://www.gdal.org/frmt_wms.html).
> Mon Nov 15 13:48:13 2021: CPLError: /wms_xml/wms_config.xml, band 1:
> IReadBlock failed at X offset 2764, Y offset 601
> Mon Nov 15 13:48:13 2021: CPLError: GetBlockRef failed at X block
> offset 2764, Y block offset 601
> The exact same data gets processed successfully in one run and not
> successfully in another run. We didn't change the code nor the Python
> or GDAL version. Hence, we are kind of puzzled as the error comes and
> goes seemingly at random.
> Does anyone of you have any hints?
> Thanks & best regards!
> Roman
> Dipl.-Ing. Roman Breitfuss-Schiffer, MSc. (GIS)
Veronikagasse 38/20, 1170 Wien
+43 664 5547678
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211119/e777e2c9/attachment.html>
