[gdal-dev] Gdal_edit and -gcp as read-only
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Nov 22 05:49:39 PST 2021
I tried to add ground control points into a TIFF file with gdal_edit. I do not want to touch the TIFF so I used the read-only option and supposed that gcp would be written into .aux.xml file but that did not happen. Instead I got a message
gdal_edit -ro -gcp 1 1 20 30 test.tif
ERROR 6: test.tif: SetGCPs() is only supported on newly created GeoTIFF files.
Without -ro gdal_edit adds ground control points into the TIFF without errors. What might be the meaning of the message about "newly created GeoTIFF" and is there some way to make gdal_edit to write ground control points into PAM file? I know that I can use gdal_translate and VRT as a workaround but PAM .aux.xml could be a bit better for my whole workflow.
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211122/7c28c85a/attachment.html>
