[gdal-dev] Gdal_edit and -gcp as read-only
Even Rouault
even.rouault at spatialys.com
Mon Nov 22 06:04:42 PST 2021
Hi Jukka,
from what I can see in
https://github.com/OSGeo/gdal/commit/b5128c1ff3ac6ad44b225284f5be1f728840e7b3,
this dates back to almost 20 years ago when SetGCPs() was initially
implemented. And at that time, PAM didn't exist yet in GDAL :-)
Please create a ticket about (and mention SetGeoTransform() and
SetSpatialRef() have the same issue)
Even
Le 22/11/2021 à 14:49, Rahkonen Jukka (MML) a écrit :
> Hi,
> I tried to add ground control points into a TIFF file with gdal_edit.
> I do not want to touch the TIFF so I used the read-only option and
> supposed that gcp would be written into .aux.xml file but that did not
> happen. Instead I got a message
> gdal_edit -ro -gcp 1 1 20 30 test.tif
> ERROR 6: test.tif: SetGCPs() is only supported on newly created
> GeoTIFF files.
> Without -ro gdal_edit adds ground control points into the TIFF without
> errors. What might be the meaning of the message about “newly created
> GeoTIFF” and is there some way to make gdal_edit to write ground
> control points into PAM file? I know that I can use gdal_translate and
> VRT as a workaround but PAM .aux.xml could be a bit better for my
> whole workflow.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211122/cba631fc/attachment.html>
