[gdal-dev] GDAL COG - Problem with Overviews
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Nov 25 04:49:13 PST 2021
Maybe the band list be zero based? Try [0,1,2].
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Nicole Kamp
Lähetetty: torstai 25. marraskuuta 2021 14.44
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] GDAL COG - Problem with Overviews
Dear GDAL Developers,
I have an overview problem with my Cloud Optimized GeoTIFF.
I tried to translate a 16 bit, 4 bands ortho image to a COG 8bit, 3 bands image with JPEG compression.
That is the original image.<https://pasteboard.co/CLur6VdD0CwQ.jpg>
That is the result.<https://pasteboard.co/MJv3lOjlI8iM.jpg>
It works fine with LZW compression, but I need the JPEG compression. What am I doing wrong?
Thanks,
Niki
Here is my code.
for raster in glob.glob(str(parameters[self.INPUT_Pfad])+'/*.tif'):
fileInfo = QFileInfo(raster)
baseName = fileInfo.baseName()
file_name = str(parameters[self.INPUT_Pfad])+'/'+baseName+'.tif'
feedback.pushInfo(file_name)
output_file1 = str(parameters[self.OUTPUT_Pfad])+'/'+baseName+'.tif'
output_file2 = str(parameters[self.OUTPUT_Pfad])+'/'+baseName+'_cog.tif'
# Create COG
x_size = 6250
y_size = 5000
num_bands = 4
src_ds = gdal.Open(file_name)
format = "GTiff"
driver = gdal.GetDriverByName(format)
# Translate
translate_options = gdal.TranslateOptions(format = 'COG', outputType = gdal.GDT_Byte, bandList = [1,2,3], scaleParams=[''],
creationOptions = ['TILED=YES','COMPRESS=JPEG','BIGTIFF=IF_NEEDED', 'BLOCKXSIZE=512', 'BLOCKYSIZE=512', 'RESAMPLING=NEAREST', 'OVERVIEWS=IGNORE_EXISTING', 'INTERLEAVE=PIXEL']
gdal.Translate(output_file1, src_ds, options=translate_options)
translate_options = None
src_ds = None
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211125/4f94ec61/attachment.html>
