[gdal-dev] Fwd: Transformation of image data between pixel/line and projected coordinates - using geolocation arrays, in both directions, without disk access
Daniel Scheffler daniel.scheffler at gfz-potsdam.de
Tue Nov 30 05:20:05 PST 2021
Ok thanks, too bad that this is not implemented. I think the inversion
of this transformation would be a nice feature to be added in GDAL. It
would be very useful to me (especially if it is accessible via the
Python bindings) and would ease the implementation in a processing
pipeline for the upcoming EnMAP hyperspectral satellite. Should I open a
feature request in the GDAL issue tracker on GitHub?
Am 30.11.2021 um 14:02 schrieb Even Rouault:
> Le 30/11/2021 à 12:52, Daniel Scheffler a écrit :
>> Thanks a lot for taking the time, Even, I got the transformation from
>> cartesian to projected coordinates to work in memory with the GTiff
>> driver. With MEM, NUMPY or VRT it does not work because these formats
>> are either not readable from /vsimem/ or don´t have a regular file
>> path which is needed to set the X_DATASET and Y_DATASET keys in the
>> GEOLOCATION metadata.
> Ah indeed for X_DATASET/Y_DATASET, you can't use a MEM or NUMPY
> dataset. But a /vsimem/xxx dataset in another format should work.
>> Regarding the inversion of this transformation, i.e., from projected
>> coordinates to pixel/line:
>>> The logic of GDALCreateGenImgProjTransformer2() around
>>> https://github.com/OSGeo/gdal/blob/master/alg/gdaltransformer.cpp#L1825
>>> which is for the source dataset should be ported a few lines after
>>> for the target dataset.  Probably with a new transformer option to
>>> be able to point to an auxiliary dataset, such as a VRT one of your
>>> example, to extract the geolocation metadata items from it, that
>>> would be different from the target dataset itself, because, except
>>> perhaps for the netCDF case, most GDAL datasets that expose a
>>> GEOLOCATION metadata domain must be read-only.
>> I don´t completely get what you mean here. To me, this sounds like
>> there might be a way to do the inverted transformation using the
>> C-API of GDAL.
> No, I meant there's some missing code to do that.
>> However, I am a Python developer and my C skills are a bit poor. Is
>> there any way to use the Python bindings here?
>> Kind regards,
>> Daniel
>> Am 26.11.2021 um 12:38 schrieb Even Rouault:
>>> Daniel,
>>>> I am trying to convert image data from cartesian/image coordinates
>>>> to projected coordinates AND vice versa using geolocation arrays in
>>>> GDAL. I have two questions:
>>>>  1. Since this transformation is part of a processing chain
>>>>     implemented in Python, I try to transform the data directly
>>>>     in-memory, i.e, without any disk access. This saves IO time and
>>>>     avoids permission errors when trying to write temporary data on
>>>>     Windows. How can this be done? I got correct results with the
>>>>     code below, however, only when I temporarily write the data to
>>>>     disk. I tried to write the data to /vsimem/ using the MEM,
>>>>     GTiff and NUMPY drivers. However, gdal.Warp can´t find the data
>>>>     there (FileNotFoundError). I think, also the gdal.Transformer
>>>>     class might be useful and I found an interesting thread on that
>>>>     here
>>>>     <https://lists.osgeo.org/pipermail/gdal-dev/2012-January/031502.html>
>>>>     and a related test in the GDAL autotest suite (here
>>>>     <https://github.com/OSGeo/gdal/blob/master/autotest/alg/transformgeoloc.py>).
>>>>     However, I can´t get it to work for my specific case.
>>> There's no reason it won't work with a in-memory dataset.
>>> If you use a MEM dataset, then you need to provide the dataset
>>> object itself as the input dataset of gdal.Warp() (the name of a MEM
>>> dataset is completely ignored. a MEM dataset can't be opened, just
>>> created).
>>> Similarly with a NUMPY dataset.   With GTiff and /vsimem/, they
>>> behave as a regular file. If you pass it by name as input of
>>> gdal.Warp(), you need to make sure to close (ds = None typically)
>>> the dataset before, so it is properly flushed and can be opened. But
>>> you can also pass it as an object without that constraint.
>>> You can also create purely in-memory VRT files by assigning them an
>>> empty name. Then of course you need to provide them as objects to
>>> gdal.Warp()
>>>>  1. My second question is how I can invert the transformation,
>>>>     i.e., how can I transform an image with projected coordinates
>>>>     back to cartesian/image coordinates, given that a geolocation
>>>>     array tells GDAL where to put which pixel in the output?
>>>>     Background is a processing pipeline for satellite data where
>>>>     some processing steps are running in sensor geometry (image
>>>>     data as acquired by the sensor, without any geocoding and
>>>>     projection) and I need to provide corresponding AUX data which
>>>>     originally come with projected coordinates.
>>>> 1.
>>>> Here is the code I already have to convert a sample image from
>>>> cartesian to projected coordinates:
>>>>     import os
>>>>     from tempfile import TemporaryDirectory
>>>>     from osgeo import gdal, osr
>>>>     import numpy as np
>>>>     from matplotlib import pyplot as plt
>>>>     # get some test data
>>>>     swath_data = np.random.randint(1, 100, (500, 400))
>>>>     lons, lats = np.meshgrid(np.linspace(3, 5, 500),
>>>>                              np.linspace(40, 42, 400))
>>>>     with TemporaryDirectory() as td:
>>>>         p_lons_tmp = os.path.join(td, 'lons.tif')
>>>>         p_lats_tmp = os.path.join(td, 'lats.tif')
>>>>         p_data_tmp = os.path.join(td, 'data.tif')
>>>>         p_data_vrt = os.path.join(td, 'data.vrt')
>>>>         p_data_mapgeo_vrt = os.path.join(td, 'data_mapgeo.vrt')
>>>>         # save numpy arrays to temporary tif files
>>>>         for arr, path in zip((swath_data, lons, lats), (p_data_tmp,
>>>>     p_lons_tmp, p_lats_tmp)):
>>>>             rows, cols = arr.shape
>>>>             drv = gdal.GetDriverByName('GTiff')
>>>>             ds = drv.Create(path, cols, rows, 1, gdal.GDT_Float64)
>>>>             ds.GetRasterBand(1).WriteArray(arr)
>>>>             del ds
>>>>         # add geolocation information to input data
>>>>         wgs84_wkt = osr.GetUserInputAsWKT('WGS84')
>>>>         utm_wkt = osr.GetUserInputAsWKT('EPSG:32632')
>>>>         ds = gdal.Translate(p_data_vrt, p_data_tmp, format='VRT')
>>>>         ds.SetMetadata(
>>>>             dict(
>>>>                 SRS=wgs84_wkt,
>>>>                 X_DATASET=p_lons_tmp,
>>>>                 Y_DATASET=p_lats_tmp,
>>>>                 X_BAND='1',
>>>>                 Y_BAND='1',
>>>>                 PIXEL_OFFSET='0',
>>>>                 LINE_OFFSET='0',
>>>>                 PIXEL_STEP='1',
>>>>                 LINE_STEP='1'
>>>>             'GEOLOCATION'
>>>>         )del ds
>>>>         # warp from geolocation arrays and read the result
>>>>         gdal.Warp(p_data_mapgeo_vrt, p_data_vrt, format='VRT',
>>>>     geoloc=True,
>>>>                   srcSRS=wgs84_wkt, dstSRS=utm_wkt)
>>>>         data_mapgeo = gdal.Open(p_data_mapgeo_vrt).ReadAsArray()
>>>>     # visualize input and output data
>>>>     fig, axes = plt.subplots(1, 4)
>>>>     for i, (arr, title) in enumerate(zip((swath_data, lons, lats,
>>>>     data_mapgeo),
>>>>                                       ('swath data', 'lons',
>>>>     'lats', 'projected data'))):
>>>>         axes[i].imshow(arr, cmap='gray')
>>>>         axes[i].set_title(title)
>>>>     plt.tight_layout()
>>>>     plt.show()
>>>> Any help would be highly appreciated!
>>>> Best,
>>>> Daniel Scheffler
>>>> M.Sc. Geogr. Daniel Scheffler
>>>> Helmholtz Centre Potsdam
>>>> GFZ German Research Centre For Geosciences
>>>> Department 1 - Geodesy and Remote Sensing
>>>> Section 1.4  - Remote Sensing
>>>> Telegrafenberg, 14473 Potsdam, Germany
>>>> Phone:  +49 (0)331/288-1198
>>>> e-mail:daniel.scheffler at gfz-potsdam.de
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> http://www.spatialys.com
>>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211130/b9aa3adb/attachment-0001.html>
