[gdal-dev] osgeo/gdal Docker Container
Nicholas Olsen
nicholas.olsen0509 at gmail.com
Fri Oct 1 10:19:58 PDT 2021
Hello,
I'm trying to use the osgeo/gdal docker container and when I'm in the
container I'm unable to successfully run gdalwarp the way I would if I were
running it through OSGEO4Win or conda. It's returning this error:
gdalwarp -multi -wo NUM_THREADS=val/ALL_CPUS -t_srs EPSG:4326 DEM.tif
warped.tif
ERROR 6: Unable to load PROJ.4 library (libproj.so), creation of
OGRCoordinateTransformation failed.
I was hoping someone might have some suggestions.
Thank you very much.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211001/504907ec/attachment.html>
