[gdal-dev] osgeo/gdal Docker Container
Even Rouault even.rouault at spatialys.com
Fri Oct 1 10:25:02 PDT 2021
This error message suggests that you're using a not super recent Docker
image. "docker pull osgeo/gdal" to refresh it
Le 01/10/2021 à 19:19, Nicholas Olsen a écrit :
> Hello,
> I'm trying to use the osgeo/gdal docker container and when I'm in the
> container I'm unable to successfully run gdalwarp the way I would if I
> were running it through OSGEO4Win or conda. It's returning this error:
> gdalwarp -multi -wo NUM_THREADS=val/ALL_CPUS -t_srs EPSG:4326 DEM.tif
> warped.tif
> ERROR 6: Unable to load PROJ.4 library (libproj.so), creation of
> OGRCoordinateTransformation failed.
> I was hoping someone might have some suggestions.
> Thank you very much.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211001/12548b03/attachment-0001.html>
