[gdal-dev] RFC 84: Migrating build systems to CMake
Even Rouault
even.rouault at spatialys.com
Tue Oct 5 06:55:18 PDT 2021
Le 05/10/2021 à 15:24, Javier Jimenez Shaw a écrit :
> I also accept some included by default, that can be disabled with an
> option. But never silently depending on what is installed.
autoconf builds largely automatically uses installed things when they
are in standard locations. That's the practice of most other projects,
which is very convenient, and that should be kept. The only requirement
for GDAL is PROJ, but if you don't have libcurl, libexpat, etc., you
loose a lot of functionality, and requiring users to list all them would
be painful.
For most packaging system, the set of dependencies available at build
time is fully controlled by the package requirements. We can assume that
whatever if available is wished to be used, and ideally a plain "cmake
.." should automatically find what is available. And if the packager
properly enumerates its build-time and run-time dependencies, that
should work.
People can explicitly disable a dependency they don't want. We could
perhaps have some option to disable everything by default, and require
explicit activation in use cases where people want full control, but
that shouldn't be the default behavior.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Tue, 5 Oct 2021 at 15:11, Greg Troxel <gdt at lexort.com
> <mailto:gdt at lexort.com>> wrote:
> Javier Jimenez Shaw <j1 at jimenezshaw.com
> <mailto:j1 at jimenezshaw.com>> writes:
> > How would CMake behave with all those options that are defined
> depending on
> > what is present on the compiler machine?
> > IMHO, the libraries included should be independent on what is
> already
> > installed on the compiler machine. The last time something/somebody
> > included "zstd" in our compiler machine, and not in the
> executing machine,
> > and we couldn't run anything. We did not need zstd, but it was
> there,
> > breaking the execution. I know that the solution there is disable it
> > "--without-zstd". What I do not like is the lack of definition,
> because
> > what is present on the compiler machine may change.
> I agree that is is best for a build to hard-require what is
> required and
> decline to use things that are not required. I don't think this
> issue
> is any different autoconf vs cmake.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211005/d32b80ff/attachment.html>
