[gdal-dev] gdal 3.3.3RC1
Even Rouault
even.rouault at spatialys.com
Tue Oct 5 07:19:53 PDT 2021
If we'd do a release each time, we fix an issue, we'd do a release each
day :-)
Use qgis-dev + gdal-dev from OSGeo4W, or you can workaround the issue by
removing the "set VSI_CACHE=TRUE" line from the qgis.bat launcher.
Le 05/10/2021 à 16:14, Nicolas Godet a écrit :
> Dear GDAL developpers,
> As describe in this QGIS issue
> (https://github.com/qgis/QGIS/issues/45293
> <https://github.com/qgis/QGIS/issues/45293>), losing network access
> during a QGIS instance cause a crash and can lead to a data loss.
> This issue was solved in the gdal PR
> (https://github.com/OSGeo/gdal/pull/4561
> <https://github.com/OSGeo/gdal/pull/4561>) and I wonder if it could be
> possible to create a release candidate of 3.3.3 version ?
> 3.3.3 is due by October 25 and next QGIS release 3.22.0 by October 22.
> So we will have to wait for QGIS 3.22.1 which for November 19.
> Combined with a DELL issue on our laptop (network interruption during
> idle…), we increase the chance of data loss…
> Regards
> Nicolas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211005/fd0e92a8/attachment-0001.html>
